[mapguide-users] Create programmatically a map
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Wed Feb 18 07:38:50 EST 2009
Very interesting... Can you check mapguide error log? Is there any
records related with this problem?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
Sent: Wednesday, February 18, 2009 12:41 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Create programmatically a map
Below you can see the new map and layout XML created from
http://localhost/mapguide/mapagent/index.html before and after the
saving
from Maestro (is equals for both).
<?xml version="1.0" encoding="UTF-8" ?>
- <ResourceList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
- <ResourceDocument>
<ResourceId>Library://.../newMap.MapDefinition</ResourceId>
<Depth>3</Depth>
<Owner>Administrator</Owner>
<CreatedDate>2009-02-18T11:31:29Z</CreatedDate>
<ModifiedDate>2009-02-18T11:31:29Z</ModifiedDate>
- <ResourceDocumentHeader
xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
- <Security xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
<Inherited>true</Inherited>
- <Groups>
- <Group>
<Name>Everyone</Name>
<Permissions>r,w</Permissions>
</Group>
</Groups>
</Security>
</ResourceDocumentHeader>
</ResourceDocument>
</ResourceList>
<ResourceId>Library://.../newLayout.WebLayout</ResourceId>
<Depth>3</Depth>
<CreatedDate>2009-02-18T11:35:51Z</CreatedDate>
<ModifiedDate>2009-02-18T11:36:32Z</ModifiedDate>
- <Groups>
- <Group>
</Group>
</Groups>
</Security>
</ResourceDocument>
</ResourceList>
Ivan Milicevic wrote:
> Please, before you open layout and map in Maestro go to:
> http://localhost/mapguide/mapagent/index.html -> go to
> Resource-->GetResourceContent--> and type correct resource ID on right
> side. See is there any strange things in output XML file. Compare it
> after saving it in Maestro.
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Wednesday, February 18, 2009 12:05 PM
> This is my problem:
> I have created programmatically a map (and its layout) using MG .Net
web
> API.
> After creation, the new map and layout are visible in MG Maestro, and
> using
> the 'Show in browser" button are correctly shown in browser.
> The problem happens when I load the map directly from browser, and the
> following error appears:
> << The type 'OSGeo.MapGuide.MgNullArgumentException' in assembly
> 'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
> PublicKeyToken=null' is not marked as serializable >>.
> Then, simply saving the new layout from MG Maestro (without any
> modification), and reloading the map directly from browser, the error
> disappears and the map is correctly shown.
> After saving the layout, there aren't differences in map and layout
XML
> definitions.
> Have you any idea about?
>> Can you write pseudo code of your task? What do you want to do? I
need
>> little more information about your problem.
>> Sent: Wednesday, February 18, 2009 11:42 AM
>> Hi Ivan,
>> below, you can see my code to create the new map:
>> Dim resID As New
>> MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
>> Dim enc As New System.Text.UTF8Encoding(False)
>> Dim newMapDef As New
> MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
>> enc.GetByteCount(XMLMapTemplate.OuterXml))
>> newMapDef.SetMimeType(MgMimeType.Xml)
>> Dim resourceSrvc As MgResourceService =
>> siteConn.CreateService(MgServiceType.ResourceService)
>> resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
>> Dim map As New MgMap()
>> map.Create(resourceSrvc, resID, MapName)
>> Then, this is my code to create the map layout:
>> Dim resID As New
>> MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
>> Dim newLayoutDef As New
>> MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
>> enc.GetByteCount(XMLLayoutTemplate.OuterXml))
>> newLayoutDef.SetMimeType(MgMimeType.Xml)
>> resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
>> map.Save(resourceSrvc)
>> Perhaps between map and layout creation I should refresh the mapframe
> as
>> suggested from you?
>> Thanks in advance for your help.
>> Fabio
>>> Can you provide us code sample?
sekko970
>>> Sent: Wednesday, February 18, 2009 10:38 AM
>>> Hi Ivan,
>>> thanks for your suggestion, but my problem is not to refresh the
>> viewer
>>> to
>>> show the map just created, but is the correct creation of new map
and
>>> layout.
>>> I think to have found the origin of my problem, but I don't
> understand
>>> the
>>> error:
>>> Argument is null. Exception occurred in method
>>> MgWebLayout.ParsePrintCommand
>>> at line 880 in file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\web\src\webapp\WebLayo
>>> ut.cpp
>>> Have you some idea?
>>> Thanks, Fabio
>>>> Hello,
>>>> You can change href of mapFrame. Here is sample code.
>>>> var mapa = "cijevi"; //defines map name
>>>> var stringMape = "Library%3a%2f%2fPROJEKTI%2fSUPRANET%2fMAPE%2f" +
>>> mapa;
>>>> var hrefMapa =
"http://172.21.10.3/mapguide/mapviewernet/mapframe.aspx?MAPDEFINITION="
>>>> + stringMape +
".MapDefinition&TYPE=HTML&SHOWLEGEND=0&SHOWPROP=0&INFOWI
DTH=0&LOCALE=en&HLTGT=1&HLTGTNAME=&SHOWSLIDER=0&SESS
>>>> ION=" + mgSessionId + ";
>>>> //changing mapFrame href
>>>> mapFrame.location.href = hrefMapa;
>>>> Hope this helps.
> sekko970
>>>> Sent: Wednesday, February 18, 2009 9:57 AM
>>>> Subject: Re: [mapguide-users] Create programmatically a map
>>>> Hi Kenneth,
>>>> I need again your help about my problem.
>>>> I think the problem is that after new map run-time creation in
>> library
>>>> repository, I cannot use its map definition to create its web
> layout.
>>>> How can I assign the new map to the layout?
>>>> Thanks again, Fabio
>>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>>> Try to look at the Maestro code:
http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Lo
>>>> calNativeConnection.cs#L182
>>>>> Hopefully you will find a small difference there.
>>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>>> sekko970 skrev:
>>>>>> Yes, the "OuterXml" property contains the XML header line.
>>>>>> Fabio
>>>>>>> Does the "OuterXml" property contain the <? version="1.0"
>>>>>>> encoding="utf-8" standalone="true" ?> line?
>>>>>>> sekko970 skrev:
>>>>>>>> Hi Kenneth, and thanks for your promptly reply.
>>>>>>>> I had used an ancoding instance.
>>>>>>>> Below, you can see my code to create the new map:
>>>>>>>> Dim resID As New
>>>>>>>> Dim resID As New
>> Nothing)
>>>>>>>> Thanks for your help.
>>>>>>>> Fabio
>>>>>>>>> You could have the problem that .Net emits an utf-8
>>>> byte-order-marker
>>>>>>>>> (BOM), when
>>>>>>>>> writing xml.
>>>>>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>>>>>> To counter this, explicitly create an encoding instance:
>>>>>>>>> System.Text.Encoding enc = new
System.Text.UTF8Encoding(false);
>>>>>>>>> Then implement a xml writer, or manually convert the xml to
>>> bytes,
>>>>>>>>> using
>>>>>>>>> the encoding.
>>>>>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a
> library,
>>>> even
>>>>>>>>> for commercial applications,
>>>>>>>>> and it handles this quirk and others.
>>>>>>>>> sekko970 skrev:
>>>>>>>>>> Dear all,
> MG
>>>> .Net
>>>>>>>>>> web
>>>>>>>>>> API.
>>> Maestro,
>>>> and
>>>>>>>>>> using
browser,
>>>> and
>>>>>>>>>> the
>> assembly
> any
> the
>>>> error
>>>> layout
>>>>>>>>>> XML
>>>>>>>>>> definitions.
>>>>>>>>>> Thank you in advance.
>>>>>>>>>> Fabio
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context:
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.htm
>>>> l
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345874.htm
>>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346122.htm
>> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346216.htm
> l
http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346367.htm
l
