[mapguide-users] Create programmatically a map
sekko970 sekko970 at virgilio.it
Wed Feb 18 11:33:47 EST 2009
The file is 21K.
I tryed also to load it directly from Maestro, and I have had no problem.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Just to be sure...
> The xml you posted is the ResourceHeader, and not the ResourceContent,
> so it does not really show what the problem may be.
> The error from the log states that the runtime map is not created, which
> is strange because a WebLayout cannot reference a runtime map.
> The other error you posted seemed to indicate that the Print command was
> invalid inside the WebLayout.
> Can you try so save the xml, just before you write it to the MgByteStream?
> Then try to post the file, using the SetResource in the webform
> mentioned earlier.
> If you get the same error, try to post the file somewhere, and provide a
> link.
> Be carefull not to copy/paste, but post the actual file.
> Btw. how large is the file? larger than 8K?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347931.html
