[mapguide-users] window open
DYUTI
dyuti152006 at yahoo.com
Fri Feb 20 02:02:51 EST 2009
hi....
thank u very much mark..
But i've still doubts in this .shall i use
$geometryFactory = new MgGeometryFactory();
$mgPolygon = $geometryFactory->Create mgPolygon($gp.x,$gp.y); "
to create mg polygons from the N/E coordinates.
Instead of "geom" u have used in vb coding shall i use this $mgPolygon.Then
for getting LayerResourceID & Schema shall i use coding or can i directly
give that values..
Thanks and regards
dyuti
Mark Pendergraft wrote:
> In VB:
> Dim geom As MgGeometry
> Dim query As New MgFeatureQueryOptions()
> query.SetSpatialFilter("Geometry", geom,
> MgFeatureSpatialOperations.Intersects)
> Dim fr as MgFeatureReader = FeatService.SelectFeatures(LayerResId,
> "Default:Temp", query)
> Note that geom is a mggeometry object used to query the layer. It could
> be a point, polygon, etc.
> LayerResId refers to the MgResourceIdentifier for a specified layer
> "Default:Temp" is the layer's schema name.
> In your case, you will probably want to create a MgPolygon from the
> point the user clicked. Then you will use the layer containing the
> points you want to display info about to get your LayerResId and default
> schema.
> -Mark
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DYUTI
> Sent: Wednesday, February 18, 2009 11:32 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] window open
> hi all.....
> any one plss tell me how to generate spatial filter.
> any suggestions will be appreciated
> thanks and Regards
> dyuti
> DYUTI wrote:
>> Thank u mark ....i'll try this
>> regards
>> dyuti
>>> Here are 2 ways to accomplish what you are trying to do:
>>> Option 1:
>>> You have a widget which inherits Fusion.Tool.Canvas.
>>> Use the mousedown even to get the coordinates clicked
>>> Then use
>>> "var p = this.getMap().getEventPosition(e);" to get the event
> position
>>> "var gp = this.getMap().pixToGeo(p.x, p.y);" to get the N/E at that
>>> position
>>> Then send your northing and easting to a PHP page and use it to
> generate
>>> a spatial filter (you may want to create a mgPolygon from your N/E as
>>> your spatialfilter in order to make sure you cover the point)
>>> Return the selected point, and send it to another page to create your
> pop
>>> up window populated with the relevant information.
>>> Option 2:
>>> Use the URL feature in studio to show a link. Use expressions to
> pass
>>> the points information into the link, and have the link directed to a
>>> custom page which will populate itself with the relevant data.
>>> Seeing as you are new to MapGuide, I would highly recommend option 2,
> as
>>> it requires very little coding and is very easy and user friendly. I
>>> have attached a photo of what the URL maptip looks like in my map.
> In
>>> the picture, the user hovers there mouse over a parcel and the maptip
>>> pops up with a link to the parcel's page on the county's website.
> All I
>>> have to do is pass the parcel number in the link, which is all done
> by
>>> studio.
>>> http://n2.nabble.com/file/n2315851/Untitled.jpg
>>> -Mark
>>> DYUTI wrote:
>>>> hi..all...
>>>> to open a new window while clicking on the points
> displayed
>>>> on the map where i've to write the coding...In which file i've to
> make
>>>> changes..&what change i've to make...plss help me...
>>>> thanks®ards
>>>> dyuti
> http://n2.nabble.com/window-open-tp2295629p2351717.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/window-open-tp2295629p2357432.html
