[mapguide-users] Layer's selection Problem
padmini godavarthi godavarthi.padmini at gmail.com
Sat Feb 21 05:24:36 EST 2009
Thanks for u r reply.
i  saw the link given by u.
but i didn't get it
can u explain the solution for this ?
Thanks and Regards,
Padmini.
miansi wrote:
> I tell you what I know J
> Here is link to other post I made - check there for possible solutions:
> http://n2.nabble.com/SQL-2008.-View-with-JOINS.-Not-able-to-select-featu
> res-on-the-layer.-td2356197.html#a2356967
> Hope that help
> From: padmini godavarthi (via Nabble)
> [mailto:ml-user+75460-387575619 at n2.nabble.com]
> Sent: Friday, February 20, 2009 2:34 AM
> To: Sinelnikov, Andrei
> Subject: Re: [mapguide-users] Layer's selection Problem
> Hi,
> But in my table i have   OBJECTID   NOT NULL NUMBER(38) .
> 1) i think i have OBJECTID as Primary key.
> 2) and i have created spatial index for geometry column.
> But it didn't selecting
> Has any solution for this?
> Thanks,
> Padmini.
> I have exactly the same behaviour for SQL 2008.
> I do not know if this is applicable for Oracle, but for SQL
> 1. You have to have Primary Key (clustered) on the table you want to
> show on the layer
> 2. PK has to be int
> 3. You have to create spatial index on the spatial column
> 4. As soon as you will try to add JOINS to your database view (if you
> trying to show layer off View) - you will lose selection functionality.
> I am fighting with this one for week already.
> Hope that will help
> padmini godavarthi wrote:
> Hi,
> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
> I have created a package using Oracle "OSGEO FDO provider for Oracle"
> and Mapguide Maestro.
> but while seeing the map by"Show in browser" the layers are does not
> selecting on map and the properties is not displaying even after i
> checked the option "Features on layer are selectable" in the map
> resource.
> Is anything i did wrong?
> Can u plz tell me the solution?
> Thanks and Regards,
> Padmini.
> ________________________________
> This email is a reply to your post @
> http://n2.nabble.com/Layer%27s-selection-Problem-tp2352146p2357923.html
> You can reply by email or by visting the link above.
> ----Notice Regarding Confidentiality----
> This email, including any and all attachments, (this "Email") is intended
> only for the party to whom it is addressed and may contain information
> that is confidential or privileged.  Sierra Systems Group Inc. and its
> affiliates accept no responsibility for any loss or damage suffered by any
> person resulting from any unauthorized use of or reliance upon this Email.
> If you are not the intended recipient, you are hereby notified that any
> dissemination, copying or other use of this Email is prohibited.  Please
> notify us of the error in communication by return email and destroy all
> copies of this Email.  Thank you.
View this message in context: http://n2.nabble.com/Layer%27s-selection-Problem-tp2352146p2363251.html
