[mapguide-users] pop up window in Ajax viewer
Maciej Skorczewski maciej.skorczewski at procad.pl
Mon Feb 23 02:32:41 EST 2009
> 1) But In which file i have to write this code?
1. javascript code pun in index file when iframe whit map is.
2. when you select some parcels on map ypu call popup.php script (in
scriptFrame)
3. in popup.php should be code to read all features from selected
object. this is place when you can make popup window.
  macieksk
