[mapguide-users] Change layer label doesn't work
    Peter Filip
    reklamama at centrum.sk
    Mon Feb 23 09:40:27 EST 2009
I changed it as you described in those examples and now it works fine.
Thank you!
Kenneth Skovhede, GEOGRAF A/S wrote:
> That is a known bug with the AJAX viewer:
> http://trac.osgeo.org/mapguide/ticket/167
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Peter Filip skrev:
>> I'm trying to change a label but without any success..
>> MgLayerCollection vrstvy = map.GetLayers();
>> vrstva1 = (MgLayer)vrstvy.GetItem(1);
>> vrstva1.LegendLabel = cinnost;
>> vrstva1.SetVisible(true);
>> vrstva1.ForceRefresh();
>> map.Save(resourceService);
>> and then i refresh the map,and the label is the same as before..
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Change-layer-label-doesn%27t-work-tp2371846p2372380.html
