[mapguide-users] Connect to MS SQL Server - problems
Stefan Dalakov
s.dalakov at mapware.net
Tue Feb 24 08:46:31 EST 2009
Thank you, Jason.
SL King provider for SQL server does not recognize Map3D geometry
columns, so I installed MS SQL server2008. Apart from the fact that
installation of Server Management Studio did not install it correctly, I
managed to transfer my 2005 database to 2008 - using FDO Bulk copy. Now
MGOS is able to connect to data, geometry type of the data in tables is
recognized but I see nothing on screen.
The error log shows :
<2009-02-24T15:26:46> Ajax Viewer 127.0.0.1 Administrator
Error: Failed to stylize layer: sql2008layer2
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot
call methods on image.
StackTrace:
- MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
RDBMS: [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot call
methods on image.
Anyone has ideas ?
Stefan Dalakov
Jason Birch wrote:
> The SQL Server 2005 provider that comes with Map 3D is proprietary, and
> not available in MapGuide Open Source. If you want to display this data
> you will need to use MapGuide Enterprise.
> If it's an option, I would suggest using the open source SQL Server 2008
> provider.
> Jason
> -----Original Message-----
> From: Stefan Dalakov
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Connect to MS SQL Server
> I have installed MS SQL Server Express Edition 2005 and have some tables
> there, created by Map3D 2009, containing lines and points.
> Which provider should I use to connect to this data as ODBC provider
> allows only point features?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
