[mapguide-users] mapguide-users Digest, Vol 24, Issue 11
northtron rnorthcott at gmail.com
Tue Feb 24 15:24:11 EST 2009
Hello,
I've done all these steps. And Double-checked them over.
I still receive the Error 500, and cannot get past the Login MapAdmin Page.
Here is my PHPInfo first section details. If anyone can help me out, I would
be appreciative.
.. run from the mapguide directory phpinfo()
PHP Version 5.2.5
System: Windows NT LONGLAND 5.2 build 3790
Build Date:  Nov 8 2007 23:18:08
Configure Command: cscript /nologo configure.js "--enable-snapshot-build"
"--with-gd=shared"
Server API:  ISAPI
Virtual Directory Support: enabled
Configuration File (php.ini) Path:  C:\WINDOWS
Loaded Configuration File: C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\Php\php.ini
PHP API: 20041225
PHP Extension: 20060613
Zend Extension: 220060519
Debug Build: no
Thread Safety: enabled
Zend Memory Manager: enabled
IPv6 Support: enabled
Registered PHP Streams: php, file, data, http, ftp, compress.zlib
Registered Stream Socket Transports: tcp, udp
Registered Stream Filters: convert.iconv.*, string.rot13, string.toupper,
string.tolower, string.strip_tags, convert.*, consumed, zlib.*
I've downloaded the EnvConfig.dll and added it as an extension to php.ini
(both locations).
I've copied the php.ini from the MapGuide /PHP folder over to c:\WINDOWS\
just to be sure.
I've setup IIS_WPG with permissions to TEMP & PHP folders.
I've double checked my Path, and moved the folder to the front of the PATH
Environment Variable.
Basically I've done everything I can gather from the previous posts, and
this post, yet no luck still.
I'm going to install MGStudio 2009 soon, and see what I can get into. But I
will need to load Packages through the WebAdmin as the datasets I use are
rather large.
Anyhow, that's my situation, and this is still persisting as a problem.
Thanks to all so far for your help
-Ryan
1. Try setting the IIS_WPG permissions on windows temp folders and php
folder
2. Make sure the php directory is at the start of the path.
3. Check the php.ini and follow the directions snipped from Crispin below...
4. Restart server.
RE: MGOS2.0.2 bundled installation won'tsupportphp on IIS6  by Crispin @
1Spatial Sep 29, 2008; 12:10pm :: Rate this Message:    - Use ratings to
moderate (?)
Reply | Reply to Author | Print | View Threaded | Show Only this Message
Folks,
File should be attached and here are our 1Spatial internal notes for getting
the PHP login page to work:
 Crispin
 *) Edit the PHP.ini file in "C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\Php"
Find the section for "Windows Extensions" and add in the two extension
entries as per below.  There will also be a "php_MapGuideApi.dll" at the
bottom of the list, comment that one out with a ";"
I once tried putting the php_MapGuideApiEnvConfig.dll entry at the bottom of
the list and something didn't work so I recommend putting both entries at
the top of the extensions.
 *) Restart IIS
;Windows Extensions
;Note that ODBC support is built in, so no dll is needed for it.
extension=php_MapGuideApiEnvConfig.dll
extension=php_MapGuideApi.dll
View this message in context: http://n2.nabble.com/RE%3A-mapguide-users-Digest%2C-Vol-24%2C-Issue-11-tp1818899p2380138.html
