[mapguide-users] Styling/AreaUsage Problem
Traian Stanev traian.stanev at autodesk.com
Wed Feb 25 11:16:28 EST 2009
It looks like the code that clips fills to polygon boundaries does not work for images and text (it works for polygon and line based fill styles). Could you create a ticket and if possible attach an mgp package file with which to test?
Thanks,
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andreas Morf
Sent: Wednesday, February 25, 2009 4:30 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Styling/AreaUsage Problem
Hi all,
I'm using a symbol definition with embedded  png-image (base64encoded) -
when applying this symbol in a polygon layer definition, the image is not
clipped at the boundaries... btw. MgOS 2.0.2 is used.
Anyone an idea!
Andreas
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
