[mapguide-users] Get the key field of ODBC table
Jackie Ng jumpinjackie at gmail.com
Thu Feb 26 18:20:42 EST 2009
Get the MgClassDefinition of the layer, then call its GetIdentityProperties()
which will return a collection of identity properties (fields/columns)
To get the MgClassDefinition, call the GetClassDefinition() method of
MgFeatureService, the MgLayer has GetFeatureSourceId() and
GetFeatureClassName() methods to give you the necessary parameters.
- Jackie
Matteo wrote:
> Hi,
>   in my map I have some layer that retriew data from MSSQL table (lat,long
> fields). Now I must be create a function that create an XLS sheets (excel)
> with table data for each object that the user select on map. For do this i
> need to get the table key field of selected object.
> I work with ASP.NET and MG2.0.2
> Someone can help me?
> Thanks
> Matteo
View this message in context: http://n2.nabble.com/Get-the-key-field-of-ODBC-table-tp2389826p2392835.html
