[mapguide-users] layerdefinitionfactory with .NET
padmini godavarthi
godavarthi.padmini at gmail.com
Tue Jan 6 01:54:21 EST 2009
Thanks for u r reply.
but i didn't get u.how can i do with LayerDefinition-1.2.0.xsd ?
actually my requirement is that i want to load thematic maps dynamically(c#
code) based on some condition..
1)how can i achieve this?
can u plz expain me the procedure for how to doit.
Thanks and Regards,
Padmini.
Kenneth Skovhede, GEOGRAF A/S wrote:
> 0)
> The classes named below can refer either to MaestroAPI classes or Xml
> tag names.
> The code given is for the MaestroAPI.
> There is no equivalent for the official API, and you will have to do
> this using Xml
> manipulation.
> Search for a file called LayerDefinition-1.2.0.xsd for a description of
> such a document.
> 1)
> Xsd:
> C:\Program
> Files\MapGuideOpenSource2.0\Server\Schema\LayerDefinition-1.2.0.xsd
> MaestroAPI:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
> 2)
> I have shown that in the sample code.
> 3)
> I have included code?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi,
>> Thanks for u r reply.But i didnt find PointRuleType anywhere?
>> 1) where can i find this?
>> 2) And how to apply properties to the layer?
>> 3) can u send me the code.
>> so that it will be very helpful.
>> Thanks and Regards,
>> Padmini
>>> I don't know where or what the LayerDefinitionFactory is, but to add
>>> thematic rules
>>> you simply add a "PointRuleType", "LineRuleType" or "AreaRuleType" to
>>> the
>>> "PointTypeStyleType", "LineTypeStyleType" or "AreaTypeStyleType"
>>> collection of the
>>> desired scalerange.
>>> eg:
>>> PointRuleType prt = new PointRuleType();
>>> prt.Filter = "\"ID\" > 100";
>>> //TODO: Set style and other properties
>>> LayerDefinition ldef; //<-- Assign this
>>> VectorLayerDefintionType vldef = ldef.Item as VectorLayerDefinitionType;
>>> //If you have more than just points, you must itterate the "Items" to
>>> find the right one
>>> PointTypeStyleType pst = vldef.VectorScaleRange[0].Items[0] as
>>> PointTypeStyleType;
>>> pst.PointRule.Add(prt);
>>>> Hi,
>>>> i want to do thematic mapping in .net .for that i suppose to use
>>>> LayerDefinitionFctory .
>>>> how to use it in .net?
>>>> can u send me the code in .net
>>>> Thanks and Regards,
>>>> Padmini
>>>> m.karam wrote:
>>>>> Hi,
>>>>> Many thanks for you Jackie
>>>>> it works good
>>>>> Regards
>>>>> Karam
>>>>> Jackie Ng wrote:
>>>>>> Hi there,
>>>>>> There is no .NET equivalent to LayerDefintionFactory. You'll have to
>>>>>> port
>>>>>> it over to .net.
>>>>>> layerdefinitionfactory.php simply takes a bunch of xml templates in
>>>>>> the
>>>>>> "viewerfiles" directory of your web extensions install folder and
>>>>>> fills
>>>>>> in the blanks with the parameters you provide.
>>>>>> example of CreateAreaRule() in .net:
>>>>>> class LayerDefinitionFactory
>>>>>> public static string CreateAreaRule(string legendLabel, string
>>>>>> filterText, string foreGroudColor)
>>>>>> StreamReader reader = new
>>>>>> StreamReader("path/to/arearule.templ");
>>>>>> string areaRuleXml = reader.ReadToEnd();
>>>>>> string [] values = new string[] { legendLabel, filterText,
>>>>>> foreGroundColor };
>>>>>> areaRuleXml = Substitute(areaRuleXml, values);
>>>>>> return areaRuleXml;
>>>>>> static String Substitute(String templ, String[] vals)
>>>>>> StringBuilder res = new StringBuilder();
>>>>>> int index = 0, val = 0;
>>>>>> bool found;
>>>>>> do
>>>>>> found = false;
>>>>>> int i = templ.IndexOf('%', index);
>>>>>> if(i != -1)
>>>>>> found = true;
>>>>>> res.Append(templ.Substring(index, i - index));
>>>>>> if(i < templ.Length - 1)
>>>>>> if(templ[i+1] == '%')
>>>>>> res.Append('%');
>>>>>> else if(templ[i+1] == 's')
>>>>>> res.Append(vals[val ++]);
>>>>>> else
>>>>>> res.Append('@'); //add a character illegal
>>>>>> in
>>>>>> jscript so we know the template was incorrect
>>>>>> index = i + 2;
>>>>>> } while(found);
>>>>>> res.Append(templ.Substring(index));
>>>>>> return res.ToString();
>>>>>> Other CreateXXX functions are variations on the above example.
>>>>>> Regards,
>>>>>> - Jackie
>>>>>> m.karam wrote:
>>>>>>> Hi everybody
>>>>>>> How can I use the (layerdefinitionfactory.php) API functions witn
>>>>>>> .NET
>>>>>>> thanks
>>>>>>> Karam
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/layerdefinitionfactory-with-.NET-tp1809201p2116477.html
