[mapguide-users] Show Multiple Properties for selection
Jackie Ng jumpinjackie at gmail.com
Wed Jan 7 00:17:03 EST 2009
This is "by design" as the AJAX viewer can only show properties for *one*
selected feature.
If you are using a Fusion-based viewer (aka. A flexible layout), it can show
multiple selections without any modification.
- Jackie
Steve G wrote:
> I am using MG 2.0.  Using MapGuide Studio 2009 I've made a data connection
> using the ODBC connection FDO (Connect via a DNS, connected to SQL Server
> database).  The connection works (I am having some performance issues, but
> that belongs in another post).  Next, I've joined this data using a
> one-to-many join with a SHP file (table from the shp file is the primary
> and data in the database is secondary).  The join seems to work ok.
> However, when I use the standard Select tool, the properties pane will
> only show one of the records in the database, I believe the first entry.
> I want to display all of the records in the joined table.
> Does anyone know how I can display multiple records in the properties
> pane?  I am using the standard ajax viewer.  Perhaps there is something to
> change in the "ajaxmappane.templ" file?  I've possibly found some code
> around line 2582 that perhaps can be manipulated?  Sorry, I am not much of
> a programmer, so any assistance would be greatly appreciated.
> Thanks,
> Steve
View this message in context: http://n2.nabble.com/Show-Multiple-Properties-for-selection-tp1819403p2120964.html
