[mapguide-users] DigitizePolygon
Paul Spencer
pagameba at gmail.com
Wed Jan 7 08:41:56 EST 2009
Unfortunately not.
Paul
On 5-Jan-09, at 1:49 PM, Mark Pendergraft wrote:
> Is there any documentation regarding how a widget should be structured
> or what functions need to be overloaded, etc? The only thing I've
> found
> is the Fusion Learning Materials which just states how to implement
> the
> widget's XML in the AppDef file.
> Mark P.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer
> Sent: Monday, January 05, 2009 7:43 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] DigitizePolygon
> I think you have bypassed something critical in the process, but I'm
> not sure. When the digitize functions are used, something needs to
> tell the digitized features that the extent has changed so they can
> redraw themselves. It should happen automatically by something
> registering for an event on the map, so something about how you've
> implemented it is probably bypassing this part. Unfortunately I
> haven't used this at all so I can't really help much with debugging.
> Perhaps Chris or Mike could comment?
> Paul
> On 4-Jan-09, at 6:35 PM, Mark Pendergraft wrote:
>> I have some questions about this function provided in the
>> MapGuideViewerApi.js file. I was wondering if anyone else is using
>> this function and if they have any issues with panning and or
>> zooming while the user is digitizing. I'm calling the function from
>> a widget and panning/zooming and refreshing the map all cause it to
>> break. I'm curious if this is an issue with my widget not telling
>> Fusion that it's active, or (the less likely of the two) if these
>> actions were overlooked when the function was designed.
>> Thanks for the help
>> -Mark Pendergraft
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
