[mapguide-users] OnSelection Event?
clarkie342
f2000342 at gmail.com
Thu Jan 8 15:40:35 EST 2009
Hi Jason,
I am trying to implement your suggestion below to make use of the
OnSelectionChanged Event Handler in mainframe.templ
I have a asp.net page with iframe showing a mapguide map. I want to be able
to do bunch of things when the user selects features on this map.
I am not very clear on how you are implementing your SelectionChanged
function instead of the original one. Where should this script go?
Appreciate your help.
Thanks
Jason Birch wrote:
> There is an OnSelectionChanged function in the main frame, but it doesn't
> appear to be documented.
> I've just tried playing around with this, and I got the following to work
> when inserted into the <head> of the ajaxviewersample.php file. It does
> not appear to work with the DWF viewer; maybe why it's not documented? Or
> it could just be that my code is bad :)
> <script type="text/javascript" >
> var originalOnSelectionChanged;
> var initTimer = setInterval(watchInitialized, 200);
> function watchInitialized () {
> try {
> if(ViewerFrame.mapFrame.mapInit)
> clearInterval(initTimer);
> originalOnSelectionChanged = ViewerFrame.OnSelectionChanged;
> ViewerFrame.OnSelectionChanged = MyOnSelectionChangedHandler;
> catch(Exception) {}
> function MyOnSelectionChangedHandler() {
> originalOnSelectionChanged ();
> var mapFrame = ViewerFrame.GetMapFrame();
> selCount = mapFrame.GetSelectedCount();
> alert("Selected: " + selCount);
> </script>
> ________________________________
> From: Willem Schwarte [mailto:willem at giskit.nl]
> Subject: [mapguide-users] OnSelection Event?
> I suppose there is no onSelectionChanged event like in MG6.5. So this
> would be done on a onClick? Where would I put the code for this?
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://n2.nabble.com/OnSelection-Event--tp1804304p2129983.html
