[mapguide-users] Session Map and Settings Serverside
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jan 8 16:39:11 EST 2009
What do you mean when you say that "visible" is read only?
You can use the "getVisible()" and "setVisible()" functions to set layer
visibility.
An example here:
http://discussion.autodesk.com/forums/thread.jspa?threadID=629000&tstart=75
The "Session:xxx//MapName.Map" is an almost empty placeholder document.
The document has a binary object attached, which is what you modify with
operations like the above.
You probably don't want to go there.
AFAIK, the map center and scale values are only stored in the client
(aka: javascript).
So you have to use the Viewer API to get/set those values.
(The DWF viewer may be different)
Regards, Kenneth Skovhede, GEOGRAF A/S
Rock Beans skrev:
> I can use the API to get layer information like what is turned on and
> off but I can't set visible since it is read only. It would be nice if
> you could just make the changes there save and issue a javascript map
> refresh. What is the best method for remembering the last location
> viewed and returning to the location with a click of a button. I
> really want to stay away from the viewer API if at all possible except
> for the refresh of course.
> I first thought I could just go layer.visible=false... no go
> Then I played with Session:xxx//MapName.Map with SetResource... is
> this the best route?
> Any ideas?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
