[mapguide-users] GT Markup sample problems
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jan 12 17:23:10 EST 2009
You can get a sort of corruption, if you manage to save xml with
a byte encoding header into the repositories.
The error below usually appears when you are using incompatible binaries, ea
using MapGuide 2.0 binaries to communicate with a 2.0.2 server.
Is it possible to render the map at all?
If not, one of the layers are likely broken for some reason.
Try removing layers from the map until it displays.
Regards, Kenneth Skovhede, GEOGRAF A/S
Warren Medernach skrev:
> This is extremely frustrating...
> I setup the GT sample app and was testing the markup functionality.
> (WinXP, IIS, MGE 2009)
> Everything was working great with creating lines and points.
> Then MG 'hiccups' and freezes up... so I have to reset IIS, restart
> the MG service to get MG back up and running.
> Now when I run the GT Markup sample I get the following error when
> attempting to markup:
> Invalid stream header exception.
> Invalid stream header exception. Exception occurred in method
> MgCommand.GetResponse at line 152 in file
> d:\buildforgeprojects\carrera_nightly\build_26.9\ent\os\common\mapguidecommon\Services/Command.cpp
> What the?!? There were no code changes, nothing, just simple reset
> after MG froze up and now this is the result?
> I thought maybe the Markup SDF got corrupted, so I deleted it, and had
> the app re-create it, still doesn't work.
> Is it possible that the repositories got corrupted?
> Any ideas on how to resolve this would be greatly appreciated.
> Thanks!
> Warren M
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090112/83458407/attachment.html
