[mapguide-users] RE: Theme layer application - point featurelayers
Arnaud De Groof
Arnaud.DeGroof at spacebel.be
Tue Jan 13 04:49:08 EST 2009
Hi Chris,
Your analysis was correct. The version of the layer definition
represents the problem. After the updating of the style template
(arearuletemplate.xml and pointruletemplate.xml) to include the extra
setting, the application is successful executed.
I have posted a new message concerning the theme layer application (see
http://lists.osgeo.org/pipermail/mapguide-users/2009-January/016237.html
) because I would apply a degraded color. Currently, the colors are
randomly distributed.
Thanks,
Arnaud
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Claydon
Sent: lundi 12 janvier 2009 17:05
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: Theme layer application - point
featurelayers
I suspect that the cause of the problem is that the Sheboygan sample
layer uses a 1.0.0 layer definition and your own layer uses a 1.1.0
layer definition. The SizeContext element was added to the StrokeType
element in the later version of the schema, thus if you want to use the
Theme code with a newer layer, you'll need to update the style template
(arearuletemplate.xml) to include the extra setting.
BTW - SizeContext can be set to either DeviceUnits or MappingUnits. If
set to DeviceUnits, the line width is interpreted in the units of your
screen, and remains constant regardless of the map scale. If set to
MappingUnits, it is interpreted as a real-world size, and thus will
increase in width on the screen as you zoom in.
Chris.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Arnaud De
Groof
Sent: Monday, January 12, 2009 7:30 AM
feature layers
Thanks for this information; I have modified the file
(../phpviewersample/theme/classes/theme.php) according your remarks.
Now, I have the possibility to select the point layers. I changed also
the different reference to the <AreaRule> by <PointRule>. I do not know
if these changes are correct because I have a problem with this function
(polygon layers), see
http://lists.osgeo.org/pipermail/mapguide-users/2009-January/016202.html
Regards,
Arnaud De Groof
Claydon
Sent: vendredi 9 janvier 2009 19:53
Subject: [mapguide-users] RE: Theme layer application - point feature
layers
The sample code generates <AreaRule> elements in a layer definition, and
therefore applies only to polygon styles. It should be relatively easy
to modify it to handle point layers and styles instead.
Groof
Sent: Friday, January 09, 2009 2:49 AM
Subject: [mapguide-users] Theme layer application - point feature layers
Hello,
Is it possible to use the application "Theme Layer" with point feature
layers? The code sample (phpviewersample/theme) allows only selecting
the polygon feature layers.
Thanks,
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090113/9d11ac43/attachment.html
