[mapguide-users] Polygons and Intersection Problem
Mark Pendergraft markp at Meadgilman.com
Thu Jan 15 12:08:39 EST 2009
Could you upload your SDF file with the 2 polygons?
-Mark P.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori
Maleski
Sent: Thursday, January 15, 2009 9:03 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Polygons and Intersection Problem
Hi All,
Intersection problem:
I have an application performs a query on a polygon layer with a point -
using intersection with the spatialfilter.
The problem is this:
The polygon originated from a shapefile - loaded as SDF via studio.
The single polygon feature originally was 2 distinct polygons dissolved
together via ArcMap.
The intersection works only on one of the polygons, and fails to return
a feature reader at all when within the other polygon.
This fails in both code execution and as a GeFeatureInfo WMS request in
the same manner.
Has anyone encountered this?
Has anyone worked around?
Is it better to explode the feature?  I require the geometery from each
part to do a highlight.
Is there an issue with how a shapefile multipolygon is converted to SDF?
Or is this an isse with the SelectFeatures functionality?
Cheers,
Kori Maleski
$geometryFactory = new MgGeometryFactory();
    // create a coordinate
    $coordinate = $geometryFactory->CreateCoordinateXY($x,$y);
    // create a point
    $point = $geometryFactory->CreatePoint($coordinate);
 $queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetSpatialFilter('Geometry',$point,MgFeatureSpatialOperat
ions::Intersects);
 $layerResource = new MgResourceIdentifier($layerdefinition);
 $layer = new MgLayer($layerResource, $resourceService);
 $layerClassName = $layer->GetFeatureClassName();
 $layerFeatureId = $layer->GetFeatureSourceId();
    $layerFeatureResource = new MgResourceIdentifier($layerFeatureId);
    $layerId = $layer->GetObjectId();
 $featureReader =
$featureService->SelectFeatures($layerFeatureResource,$layerClassName,$q
ueryOptions);
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090115/460d4722/attachment.html
