[mapguide-users] Create map in the session
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jan 15 15:46:22 EST 2009
The result you are getting is correct. There is a dummy placeholder for
the runtime map.
The error you are getting is because the render expects there to be an
(empty) selection, and it is missing.
The C# code is like this:
MgSelection sel = new MgSelection(map);
sel.Save(resourceSrvc, mapName);
Take a look at the "mapframe.php" to find the code in PHP.
Regards, Kenneth Skovhede, GEOGRAF A/S
gingerbbm skrev:
> Hi Kenneth
> If I issue GetResourceContent on Session:..//mapname.Map (as opposed to
> .MapDefinition) I don't get an error. I get simply "<Map/>".
> I'm not interested in the viewer - I simply want to issue the HTTP query and
> do something with the XML that (hopefully) is returned. If I in fact try the
> query having run the previous PHP, i.e.
> http://.../mapguide2009/mapagent/mapagent.fcgi?GEOMETRY=POLYGON((3 2,4 2,4
> 3,3 3,3
> 2))&MAXFEATURES=1&OPERATION=QUERYMAPFEATURES&PERSIST=0&SELECTIONVARIANT=INTERSECTS&MAPNAME=...&SESSION=...&VERSION=1.0.0
> I get the following error:
> Invalid argument(s): The value cannot be less than or equal to zero.
> Exception occurred in method MgServerRenderingService.RenderForSelection at
> line 1041 in file
> d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\rendering\ServerRenderingService.cpp
