[mapguide-users] Consuming WFS, error in MGE2009
Gary Morin gary.morin at keynetix.com
Fri Jan 16 08:05:34 EST 2009
Yes, I got WMS working, I just had to remove <time>current</time> from the
sample config.xml, GeoServer reported an error when it was in the config.
I just need to get WFS working now
Gary
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nisha P
Sent: 16 January 2009 11:58
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Consuming WFS, error in MGE2009
Hi...
Did u got WMS data by using this link?
http://trac.osgeo.org/fdo/wiki/FdoWmsNotes
<http://trac.osgeo.org/fdo/wiki/FdoWmsNotes%29>
On Fri, Jan 16, 2009 at 4:03 PM, Gary Morin <gary.morin at keynetix.com>
wrote:
Can any one help or give me a pointer?
I've done more work and have WMS working and by following the notes
http://trac.osgeo.org/fdo/wiki/FdoWmsNotes, and have transparency and the
correct coordinates system working.
But I still have no joy with WFS in MGE 2009 even though I have it working
in Map 2009.
Any help will be much appreciated.
Regards
Gary
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gary Morin
Sent: 15 January 2009 10:31
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] Consuming WFS, error in MGE2009
I'm using MGE 2009 and trying to consume a WFS published by Geoserver.
I'm using Stuido author, create an data connection to the WFS works fine,
and I can create a layer, but when I attempt to preview the layer no data
is shown and an error is logged. The same WFS work fine in AutoCAD Map
2009
<2009-01-15T10:15:12>              127.0.0.1           Administrator
 Error: Failed to stylize layer: tiger landmarks
        An exception occurred in FDO component.
        Schema can not be found in the collection.
 StackTrace:
  - MgMappingUtil.StylizeLayers line 786 file
d:\build\carrera_nightly\build_34.2\ent\os\server\src\services\mapping\Map
pingUtil.cpp    Failed to stylize layer: tiger landmarks
Looking in the mail list archived I found a similar problem reported march
2008
http://n2.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-someon
e---tt1815194.html#a1815194
Was the problem ever fixed, or is this a new problem?
Thanks
Gary
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Nisha P
IIITM-K
nisha at iiitmk.ac.in
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090116/23a797ef/attachment.html
