[mapguide-users] Add new layer to map
sekko970
sekko970 at virgilio.it
Tue Jan 20 08:36:07 EST 2009
Dear all,
I need to add a layer to my map from XML definition.
This is my code:
Public Sub CreateLater(ByVal sessionID As String, ByVal mapName As
String, _
ByVal newLayerName As String, ByVal
groupName As String)
Dim userInfo As New MgUserInformation
userInfo.SetMgSessionId(sessionID)
Dim siteConn As New MgSiteConnection
siteConn.Open(userInfo)
Dim resourceSrvc As MgResourceService =
siteConn.CreateService(MgServiceType.ResourceService)
Dim map As New MgMap()
map.Open(resourceSrvc, mapName)
'Loading XML layer
Dim newLayerXML As New XmlDocument
newLayerXML.Load(Me.MapPath("NewLayer.xml"))
'Saving new layer in session repository
Dim byteSource As New
MgByteSource(Encoding.UTF8.GetBytes(newLayerXML.OuterXml),
newLayerXML.OuterXml.Length)
byteSource.SetMimeType(MgMimeType.Xml)
Dim resID As New MgResourceIdentifier("Session:" & sessionID & "//"
& newLayerName & "." & MgResourceType.LayerDefinition)
resourceSrvc.SetResource(resID, byteSource.GetReader(), Nothing)
Dim newLayer As New MgLayerBase(resID, resourceSrvc)
'Add new layer to group
Dim layerGroup As MgLayerGroup = Nothing
If map.GetLayerGroups().Contains(groupName) Then
layerGroup = map.GetLayerGroups.GetItem(groupName)
Else
layerGroup = New MgLayerGroup(groupName)
layerGroup.SetVisible(True)
layerGroup.SetDisplayInLegend(True)
layerGroup.SetLegendLabel(groupName)
map.GetLayerGroups.Add(layerGroup)
End If
newLayer.SetGroup(layerGroup)
'Insert new layer to map
newLayer.SetName(newLayerName)
newLayer.SetVisible(True)
newLayer.SetLegendLabel(newLayerName)
newLayer.SetDisplayInLegend(True)
map.GetLayers.Insert(0, newLayer)
map.Save(resourceSrvc)
Saving the map, an MgNotImplementedException occurs.
Where is my mistake?
Thanks in advance for your help.
Fabio
View this message in context: http://n2.nabble.com/Add-new-layer-to-map-tp2186494p2186494.html
