[mapguide-users] Add new layer to map
Mark Pendergraft
markp at Meadgilman.com
Wed Jan 21 10:44:59 EST 2009
Are you trying to add permanent layers to the map?
Does this need to happen at runtime?
-Mark
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Wednesday, January 21, 2009 2:24 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Add new layer to map
I don't understand what you mean.
Changes to the runtime map does not go into MGStudio.
Only changes to the MapDefinition xml can be seen there.
Regards, Kenneth Skovhede, GEOGRAF A/S
sekko970 skrev:
Dear Kenneth,
I need your help for a second problem:
I apparently save successfully the new layer into library repository
(the
legend and the map are correctly updated, and from MGStudio the new
layer is
visible in layers list), but in MGStudio 'Layer by group' view, my layer
doesn't appear, so that when I reload the map, the new layer is lost
(but
it's present in MGStudio).
Have you some idea?
Thanks, Fabio
sekko970 wrote:
You are right!
Many thanks.
Fabio
sekko970 wrote:
Dear all,
I need to add a layer to my map from XML definition.
This is my code:
Public Sub CreateLater(ByVal sessionID As String,
ByVal mapName As
String, _
ByVal newLayerName As
String, ByVal
groupName As String)
Dim userInfo As New MgUserInformation
userInfo.SetMgSessionId(sessionID)
Dim siteConn As New MgSiteConnection
siteConn.Open(userInfo)
Dim resourceSrvc As MgResourceService =
siteConn.CreateService(MgServiceType.ResourceService)
Dim map As New MgMap()
map.Open(resourceSrvc, mapName)
'Loading XML layer
Dim newLayerXML As New XmlDocument
newLayerXML.Load(Me.MapPath("NewLayer.xml"))
'Saving new layer in session repository
Dim byteSource As New
MgByteSource(Encoding.UTF8.GetBytes(newLayerXML.OuterXml),
newLayerXML.OuterXml.Length)
byteSource.SetMimeType(MgMimeType.Xml)
Dim resID As New MgResourceIdentifier("Session:"
& sessionID &
"//" & newLayerName & "." &
MgResourceType.LayerDefinition)
resourceSrvc.SetResource(resID,
byteSource.GetReader(), Nothing)
Dim newLayer As New MgLayerBase(resID,
resourceSrvc)
'Add new layer to group
Dim layerGroup As MgLayerGroup = Nothing
If map.GetLayerGroups().Contains(groupName) Then
layerGroup =
map.GetLayerGroups.GetItem(groupName)
Else
layerGroup = New MgLayerGroup(groupName)
layerGroup.SetVisible(True)
layerGroup.SetDisplayInLegend(True)
layerGroup.SetLegendLabel(groupName)
map.GetLayerGroups.Add(layerGroup)
End If
newLayer.SetGroup(layerGroup)
'Insert new layer to map
newLayer.SetName(newLayerName)
newLayer.SetVisible(True)
newLayer.SetLegendLabel(newLayerName)
newLayer.SetDisplayInLegend(True)
map.GetLayers.Insert(0, newLayer)
map.Save(resourceSrvc)
Saving the map, an MgNotImplementedException occurs.
Where is my mistake?
Thanks in advance for your help.
Fabio
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090121/d1267f32/attachment.html
