[mapguide-users] Two maps in the same layout
Mark Pendergraft markp at Meadgilman.com
Wed Jan 21 11:15:13 EST 2009
Roldolfo,
Sorry I didn't look at your code.  It's pretty much exactly the same as
what I posted.  Why would you need to modify any of the viewer files in
order to have 2 pages in your map?
I was able to create a 2 map page using framesets in the same manner
that you did.
-Mark
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
Pendergraft
Sent: Wednesday, January 21, 2009 8:10 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Two maps in the same layout
Many people have their page in a frameset.  Here is an example which has
two frames, 1 for a title.html page and 1 for the mapguide viewer.  Here
is an example of what your frameset page might look like (in VB.NET)
<%@ Page Language="VB" Debug="true" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
<!-- #Include File="UtilityFunctions.aspx" -->
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<script runat="server">
    Private webLayout As String = "Library://MGA/Layout/MGA Web
Layout.WebLayout"
    Private defaultUser As String = "Anonymous"
    Private defaultPassword As String = ""
    Private SessionId As String = ""
    Private addRequests As String = ""
    Private Parameters As String = ""
</script>
    Try
        ' Initialize a session and register a variable to hold the
        ' session id, then initialize the Web Extensions, connect
        ' to the site, and create a session.
        InitializeWebTier()
        Dim userInfo As New MgUserInformation(defaultUser,
defaultPassword)
        Dim site As New MgSite()
        site.Open(userInfo)
        SessionId = site.CreateSession()
    Catch ex As Exception
        Response.Write(ex.Message)
    End Try
<frameset rows="50,*">
    <frame id="titleFrame" frameborder="0" marginwidth="0"
marginheight="0" scrolling="no"
        src="http://localhost/mapguide/mga/title.html">
    <frame id="viewerFrame" frameborder="0" marginwidth="0"
src="http://localhost/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=s
essionId%>&WEBLAYOUT=<%=webLayout%>&LOCALE=en">
</frameset>
This page creates a horizontal split page with two pages in it.  If you
adjusted frameset rows="50,*" to "frameset cols="*,*" you would get a
page split in half vertically.  Then change the src="" element to the
two pages you want shown.
Hope that clears it up a bit.
-Mark Pendergraft
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
Moreno
Sent: Wednesday, January 21, 2009 7:47 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Two maps in the same layout
Hi Jackie,
I don't understand what you want to tell me, could you elaborate on your
idea?
this the code of my beginning page
String webLayout =
"Library://Samples/Sheboygan/Layouts/SheboyganAspTest.WebLayout";
String defaultUser = "Anonymous";
String defaultPassword = "";
String sessionId1 = "";
String sessionId2 = "";
</script>
    try
        // Initialize a session and register a variable to hold the
        // session id, then initialize the Web Extensions, connect
        // to the site, and create a session.
        InitializeWebTier();
        MgUserInformation userInfo = new MgUserInformation(defaultUser,
defaultPassword);
        MgSite site = new MgSite();
        site.Open(userInfo);
        sessionId1 = site.CreateSession();
        sessionId2 = site.CreateSession();
    catch (Exception e)
        Response.Write(e.Message);
<html>
<head>
	<title>Viewer Sample Application</title>
</head>
<frameset rows="30,*" frameborder="no" framespacing="0">
 <frame id="titleFrame" frameborder="no" marginwidth="0"
marginheight="0"
scrolling="no" src="title.html">
  <frameset cols="50%,50%">
    <frame id="viewer1Frame" frameborder="no" marginwidth="0"
src="/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId1%>&WEBL
AYOUT=<%=webLayout%>&THEMINGTYPE=1">
	    <frame id="viewer2Frame" frameborder="no" marginwidth="0"
src="/mapguide/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId2%>&WEBL
AYOUT=<%=webLayout%>&THEMINGTYPE=2">
  </frameset>
</frameset>
</html>
thanks,
Jackie Ng wrote:
> The easiest way is to have an outer frameset (or 2 outer iframes) that
> points to your individual ajax viewers.
> - Jackie
> Rodolfo Moreno wrote:
>> I want to put two maps in the same layout and moreover each map must
be
>> themed in different way just after of that the application to be
loaded
>> (the theming must be done automatically according to a placed
preference
>> in the first time that the application to be loaded).
>> I did a test application usign ajax viewer and I got it, however I
have
>> modified many files of the mapguide extensions (MAINFRAME.ASPX,
>> FRAMESETTASKBAR.TEMPL, FRAMESETNOTASKBAR.TEMPL, MAPFRAME.ASPX,
>> AJAXMAPPANE.TEMPL).
>> I would like to know if it's possible to achieve it without the need
of
>> modifying that files?
>> Also I'd like to know if it's possible to do it in FUSION viewer (I
>> prefer FUSION than AJAXVIEWER).
>> I am attaching a image of my test application.
>> thanks in advance,
>>  http://n2.nabble.com/file/n2189508/testApp.jpg
Rodolfo Moreno
CivilEng
View this message in context:
http://n2.nabble.com/Two-maps-in-the-same-layout-tp2189508p2192823.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
