[mapguide-users] Hyperlink not showing
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jan 22 05:00:30 EST 2009
A nice trick is to use an URL starting with "javascript:", ea:
"javascript:alert('hello');".
Then the javascript can call any function you have and display the
options to the user.
You wont get any links active without using the "URL Activated for Feature".
You can use the above "javascript:" trick for the URL.
Tooltips can show embedded html, but disappear when the mouse moves,
making it hard to use.
Regards, Kenneth Skovhede, GEOGRAF A/S
LLEUNDD skrev:
> I have an attribute in one of my point layers called 'hyperlink'.  When I
> select a point in a flexible web layout (i.e., Slate) the selection widget
> shows the hyperlink address, but I can not click on the address to advance
> to the website.
> I know I can use the 'URL Activated for Feature' in the layer editor,
> however I may have points that would have multiple hyperlinks to chose from.
> I have tried the following in the attributes for the point layer with no
> success:
> 1. www.123.com
> 2. http://www.123.com
> 3. a href="http://www.123.com"> 123</a
> I have MGOS version 2.0.0.2308 installed and am using Autodesk MapGuide
> Studio 2008.
> Any help would be appreciated.
> Cheers!
