[mapguide-users] Adding a temporary Layer in MapGuide
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jan 22 05:09:57 EST 2009
In the buffer.aspx, the AddFeatureToCollection(...) function adds the
feature.
The MgGeometry parameter can be created using the MgGeometryFactory:
http://mapguide.osgeo.org/files/mapguide/docs/2.0/d4/d46/class_mg_geometry_factory.htm
I don't know what happens with the exception, but it has something to do
with selection,
which you can hopefully ignore.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> As I said on my last post, I successfully linked the buffer code to
> the Task Panel item. But there is a problem, when the buffer code is
> executed I get this runtime error:
> Buffer Error
> An unclassified exception occurred. Exception occurred in method
> new_MgSelection__SWIG_1 at line 649 in file .\MgApi_wrap.cpp
> I followed these steps to link the buffer code to the Task Panel:
> - In DevGuideSamples\JAVASAMPLES\HELLO_MAP there are TASK_PANE.JSP and
> DISPLAY_SPATIAL_REFERENCE.JSP.
> TASK_PANE.JSP is linked to the Task Panel, and it calls
> - In mapviewerjava there is buffer.jsp
> - I copied the buffer.jsp code into the DISPLAY_SPATIAL_REFERENCE.JSP
> file
> How can I solve that problem?
> You said to insert points instead of the buffer feature. How? Points
> (or a line in a similar task) have coordinates stored on a MySql
> database...
> ----- Original Message ----- From: "Kenneth Skovhede, GEOGRAF A/S"
> <ks at geograf.dk>
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, January 21, 2009 11:24 AM
> Subject: Re: [mapguide-users] Adding a temporary Layer in MapGuide
>> Yes, just insert points instead of the buffer feature.
>>> Thank you for your reply Kenneth.
>>> Trying examples on DevGuideSamples I discovered how to work with the
>>> Task Pane...
>>> Now I need to draw dynamically on the map points of known x,y
>>> coordinates, after clicking on the appropriate Task item. I hope
>>> this can be done with the buffer script you suggested me. Isn't it?
>>> Cheers
>>> Carmelo
>>> <ks at geograf.dk>
>>> Sent: Wednesday, January 21, 2009 9:04 AM
>>>> I have not used the AJAX viewer enough to know how to do this with
>>>> tasks.
>>>> The values can be read from the viewer through some property
>>>> functions:
>>>> http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getsessionid
>>>> http://mapguide.osgeo.org/files/mapguide/docs/2.0/viewerapi.html#mapframe_getmapname
>>>> With those, you can manually pass them to the request, if you use
>>>> the "InvokeScript" method,
>>>> but there may be an easier way.
>>>>> Thank you for your help!
>>>>> I'm seeing that the code you posted is very similar to the buffer
>>>>> code, however I'm really new to MapGuide, so I hope you can help
>>>>> me understanding how to make it work.
>>>>> I created a Layout, using MapGuide Studio, on which I added a new
>>>>> custom command for the Task panel, named "Route tracing".
>>>>> Therefore I created the route_tracing.jsp file, on which I'm
>>>>> trying to use your code (translating it from PHP to JSP) or the
>>>>> buffer.jsp code (which is already in JSP).
>>>>> On both your code and buffer.jsp there is this code:
>>>>> mapName = GetParameter(request, "MAPNAME");
>>>>> sessionId = GetParameter(request, "SESSION");
>>>>> - The question is: how can I pass the MAPNAME and SESSION values
>>>>> to the web page?
>>>>> The final result should be a web page, which opens when its Action
>>>>> Task item is clicked, on which I can select and digit some
>>>>> options. After clicking a button the page should get these values,
>>>>> and display the map with the calculated additional layer on it.
>>>>> I hope you can help me about that
>>>>> Cheers
>>>>> Carmelo
>>>>> ----- Original Message ----- From: "Arnaud De Groof"
>>>>> <Arnaud.DeGroof at spacebel.be>
>>>>> Sent: Monday, January 12, 2009 4:18 PM
>>>>> Subject: RE: [mapguide-users] Adding a temporary Layer in MapGuide
>>>>> The first code :
>>>>> <?php
>>>>> // Vital includes.
>>>>> include "../../mapviewerphp/constants.php";
>>>>> include "../../mapviewerphp/common.php";
>>>>> $args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
>>>>> $sessionId = $args['SESSION'];
>>>>> $mapName = $args['MAPNAME'];
>>>>> $layerName1 = 'YYY';
>>>>> $rlLayerResourceId = "Library://XXX/$layerName1.LayerDefinition";
>>>>> InitializeWebTier();
>>>>> $userInfo = new MgUserInformation($sessionId);
>>>>> $siteConnection = new MgSiteConnection();
>>>>> $siteConnection->Open($userInfo);
>>>>> $resourceService =
>>>>> $siteConnection->CreateService(MgServiceType::ResourceService);
>>>>> // Read the MapDefinition into an XML DOM document object.
>>>>> $md = " Library://XXX/$mapName.MapDefinition "; // TODO Constant!
>>>>> $mdResourceId = new MgResourceIdentifier($md);
>>>>> $mdReader = $resourceService->GetResourceContent($mdResourceId);
>>>>> $mdXml = $mdReader->ToString();
>>>>> $mdDomDoc = DOMDocument::loadXML($mdXml);
>>>>> // Add a new MapLayer
>>>>> $targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
>>>>> $newNode = $targetNode->parentNode->insertBefore(new
>>>>> DOMElement("MapLayer"), $targetNode);
>>>>> $newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
>>>>> $newNode->appendChild($mdDomDoc->createElement("ResourceId",
>>>>> $rlLayerResourceId));
>>>>> $newNode->appendChild($mdDomDoc->createElement("Selectable",
>>>>> "false"));
>>>>> $newNode->appendChild($mdDomDoc->createElement("ShowInLegend",
>>>>> "false"));
>>>>> $newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
>>>>> $newNode->appendChild($mdDomDoc->createElement("ExpandInLegend",
>>>>> "false"));
>>>>> $newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
>>>>> $newNode->appendChild($mdDomDoc->createElement("Group"));
>>>>> // Save the updated MapDefinition
>>>>> $updatedXml = $mdDomDoc->saveXML();
>>>>> $byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
>>>>> // Create the temporary MapDefinition
>>>>> $sessionMapName = $mdResourceId->GetName();
>>>>> $sessionMapDefinition =
>>>>> "Session:$sessionId//$sessionMapName.MapDefinition";
>>>>> $sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
>>>>> // Write the updated MapDefinition
>>>>> $resourceService->SetResource($sessionResourceId,
>>>>> $byteSource->GetReader(), null);
>>>>> //Test the updated MapDefinition
>>>>> $md1 = "Session:$sessionId//X.MapDefinition";
>>>>> $mdResourceId2 = new MgResourceIdentifier($md1);
>>>>> $mdReader2 = $resourceService->GetResourceContent($mdResourceId2);
>>>>> $mdXml2 = $mdReader2->ToString();
>>>>> $mdDomDoc2 = DOMDocument::loadXML($mdXml2);
>>>>> // Read the WebLayout into an XML DOM document object.
>>>>> $wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
>>>>> $wlResourceId = new MgResourceIdentifier($wl);
>>>>> $wlReader = $resourceService->GetResourceContent($wlResourceId);
>>>>> $wlXml = $wlReader->ToString();
>>>>> $wlDomDoc = DOMDocument::loadXML($wlXml);
>>>>> // Now, update the MapDefinition.
>>>>> $mapdef = $wlDomDoc->getElementsByTagName("ResourceId")->item(0);
>>>>> $mapdef->nodeValue = "$md1";
>>>>> // Prepare the updated XML to be written out to the session.
>>>>> $wlupdatedXml = $wlDomDoc->saveXML();
>>>>> $wlbyteSource = new MgByteSource($wlupdatedXml,
>>>>> strlen($wlupdatedXml));
>>>>> // Create a temporary WebLayout
>>>>> $wlsessionMapName = $wlResourceId->GetName();
>>>>> $wlsessionWebLayout =
>>>>> "Session:$sessionId//$wlsessionMapName.WebLayout";
>>>>> $wlsessionResourceId = new MgResourceIdentifier($wlsessionWebLayout);
>>>>> // Write the updated WebLayout to the session.
>>>>> $resourceService->SetResource($wlsessionResourceId,
>>>>> $wlbyteSource->GetReader(), null);
>>>>> // Redirect to the Ajax viewer.
>>>>> $redirectTo =
>>>>> "mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayou
>>>>> t";
>>>>> $host = $_SERVER["HTTP_HOST"];
>>>>> $url = "http://$host/$redirectTo";
>>>>> //Test
>>>>> $f = 'test.txt';
>>>>> $handle = fopen($f,"w");
>>>>> fwrite($handle, "test1:<".$mdXml.">\r\ntest 2
>>>>> :<".$updatedXml.">\r\ntest
>>>>> 3 :<".$wlXml.">\r\ntest 4 :<".$wlupdatedXml.">\r\ntest 5
>>>>> :<".$url.">");
>>>>> fclose($handle);
>>>>> // Redirect!
>>>>> header("Location: $url");
>>>>> exit;
>>>>> ___________________________________________________________________________________
>>>>> E-MAIL DISCLAIMER
>>>>> The present message may contain confidential and/or legally
>>>>> privileged information.
>>>>> If you are not the intended addressee and in case of a
>>>>> transmission error,
>>>>> please notify the sender immediately and destroy this E-mail.
>>>>> Disclosure, reproduction or distribution of this document and its
>>>>> possible
>>>>> attachments is strictly forbidden.
>>>>> SPACEBEL denies all liability for incomplete, improper,
>>>>> inaccurate, intercepted,
>>>>> (partly) destroyed, lost and/or belated transmission of the
>>>>> current information
>>>>> given that unencrypted electronic transmission cannot currently be
>>>>> guaranteed
>>>>> to be secure or error free. Upon request or in conformity with
>>>>> formal, contractual
>>>>> agreements, an originally signed hard copy will be sent to you to
>>>>> confirm
>>>>> the information contained in this E-mail.
>>>>> SPACEBEL denies all liability where E-mail is used for private use.
>>>>> SPACEBEL cannot be held responsible for possible viruses that
>>>>> might corrupt this
>>>>> message and/or your computer system.
>>>>> ____________________________________________________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
