[ZS2] Re: [mapguide-users] [ZS2] Draw Point From Invoke Script n c# script
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jan 22 05:12:43 EST 2009
Try looking at the file:
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewernet\buffer.aspx
It has a fair amount of comments in it.
You should replace the calls to AddFeatureToCollection, so you insert a
point,
instead of a buffered feature.
Regards, Kenneth Skovhede, GEOGRAF A/S
Kenneth Skovhede, GEOGRAF A/S skrev:
> Nope.
> If you do manage to get it done, others would benefit from an example:
> http://trac.osgeo.org/mapguide/wiki/CodeSamples/AspDotNet/TemporaryMarkupsDotNet
> Try using the "Buffer" feature of the MapGuide AJAX viewer to see how
> it works.
> Alternatively, the Scribble application may have some usefull code:
> http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
> ajid skrev:
>> Ermm Can u give a example??
>> ::: PublicVisitor :::
>> www.myguidepages.com
