[mapguide-users] Fusion php application - error session ID
Arnaud De Groof Arnaud.DeGroof at spacebel.be
Fri Jan 23 11:23:31 EST 2009
I try to use the php application "theme layer" in a Fusion layout
without success. The following error is encountered during the process:
Error
Invalid argument(s): [1] = "" The session ID is invalid because the
session separator character was not found.
session separator character was not found. Exception occurred in method
MgUserInformation.SetMgSessionId at line 183 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecomm
on\System/UserInformation.cpp
Could you help me the resolve this issue because with a normal layout,
there is no error?
Thanks.
Regards,
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090123/33d8c37d/attachment.html
