[mapguide-users] Adding customized line types
Stefan Dalakov s.dalakov at mapware.net
Fri Jan 23 13:24:27 EST 2009
Hi, I think you can use this link as a departure point for creating
custom line styles
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc14
And I am not sure I understand the second part of this message. Do you
mean "object data" in Map 3D terms?
Could you explain more ?
Best regards : Stefan Dalakov
ray at rayholtz.com wrote:
> I'm resending this in the hopes that maybe the person that might have
> this knowledge missed it the first time around.
> Thanks!
>     -------- Original Message --------
>     Subject: [mapguide-users] Adding customized line types
>     From: ray at rayholtz.com
>     Date: Wed, January 21, 2009 5:21 pm
>     To: mapguide-users at lists.osgeo.org
>     Hi, we have Mapguide OpenSource 1.2 running on Ubuntu 7.04, and
>     using Mapguide Studio 2008, and AutoCad Map 3D 2008.
>     We have a defined line type file in Map 3D, that we need to
>     import/install/get working within Mapguide Studio and MGOS.
>     Furthermore, we have blocks in Map 3D created for manhole covers
>     that we want to be endpoints for these lines.  The manhole cover
>     has been scanned in as a jpg. we are unable to attach object data
>     to it.  How do we export the manhole cover from Map 3D into
>     MapGuide Studio/MGOS so we can attach object data to it?
>     Thanks much for the infininate wisdom of this list!!!
>     Ray
>     _______________________________________________
>     mapguide-users mailing list
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090123/002e9149/attachment.html
