[mapguide-users] Ajax Viewer and Digitizing - may be a bug
Stefan Dalakov s.dalakov at mapware.net
Mon Jan 26 03:16:33 EST 2009
Hi all,
I encountered a strange bug with the Ajax Viewer. I had a module for
digitizing polygons, which was placed as InvokeURL command in the Task
Pane. Now I transformed it to an InvokeScript command and it is started
through the top toolbar as a part of a Flyout - drops down in a menu.
The bug is that, when I click on this dropdown menu to activate the
DigitizePolygon function, the first vertex of the polygon is
automatically placed where I have clicked to activate the function - the
point on the map that was behind the menu. My workaround in this
situation is to fire an alert box, displaying a message, which clears
the buffer and then everything goes like expected.
Has any body noticed such an effect / defect / bug? Is it possible to be
a bug in my code ?
The behavior is the same in IE, FFox and Safari
It is MGOS 2.02
Stefan Dalakov
