[mapguide-users] Second instance
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jan 26 09:31:52 EST 2009
If you have two different services running, you can exchange packages
between them.
Physical machine location is irrelevant, but most users have seperate
machines.
MapGuide is fairly demanding on memory and CPU power, so I would not
recommend
running more than one instance on each machine. Installation and
configuration of the
second service is also quite a pain.
Regards, Kenneth Skovhede, GEOGRAF A/S
Atika Irfan skrev:
>     Yes, you can create a package on one machine, and then load it on
>     another machine.
>     that means we cant have both instances with different IP's on the
>     same machine ?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090126/444675a0/attachment.html
