[mapguide-users] Fusion and Digitizing
Paul Spencer pagameba at gmail.com
Fri Jan 30 07:16:23 EST 2009
Thanks guys ... the digitizing code has changed in the upcoming 2.0
release to use the OpenLayers vector library rather than our home-
grown canvas implementation so we'll make sure there is a way to clean
up after digitizing ...
Mike, can you take a skim through this thread and make sure the new
Vector implementation has a method for cleaning up, or implicitly
cleans up if possible.
Cheers
Paul
On 29-Jan-09, at 6:14 PM, Mark Pendergraft wrote:
> thanks!
> I'll take a look at it later tonight.
> -Mark
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Thursday, January 29, 2009 3:02 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Fusion and Digitizing
> Hi Mark, I have gotten to clear the digitized polygons in FUSION
> viewer
> by
> modifying the MapGuideViewerapi.js
> var polDigitizer;
> function DigitizePolygon(handler) {
>    if (handler) {
>      var Fusion = window.top.Fusion;
>      var mapWidget = Fusion.getWidgetById(mapWidgetId);
>      var digitizer = new Fusion.Tool.Canvas.Polygon(mapWidget);
>      digitizer.mouseDown = MultiPointHandlers.prototype.mouseDown;
>      digitizer.mouseMove = MultiPointHandlers.prototype.mouseMove;
>      digitizer.dblClick = MultiPointHandlers.prototype.dblClick;
>      Object.inheritFrom(digitizer, Fusion.Tool.Canvas.prototype, []);
>      digitizer.handler = handler;
>      digitizer.activateCanvas();
>      polDigitizer = digitizer;
>      //add a listener to update the position of the features
>      mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED,
> extendEvtResponse );
> function extendEvtResponse(){
>  var digitizer = polDigitizer;
>  digitizer.updatePx();
>  digitizer.clearContext();
>  digitizer.draw(digitizer.context);
> function clearPol(){
>   polDigitizer.clearContext();
>   mapWidget.deregisterForEvent(Fusion.Event.MAP_EXTENTS_CHANGED,
> extendEvtResponse);
>   polDigitizer.deactivateCanvas();
> In your main page you must call to clearPol() function in order to
> clear
> the
> digitized polygon. For the other shapes I guess that the logic is the
> same.
> The above code only clears the last polygon digitized. It's
> necessary to
> manage an array of digitizers for controlling all digitized
> polygons. I
> haven't had time for trying it.
> I have tested with mapguide 2.0.1 with FUSION 1.0.6 in IE7 and FF2
> maybe you can improve it.
> Regards,
> GordonL wrote:
>> Hi Mark,
>> I know what you mean about the sticky digitizing... I was told to
>> look
> at
>> the
>> resetCanvas function in the Measure.js file to get rid of that
> leftover
>> digitize graphics...but I haven't tried it yet...
>> gordon
>>> I was in no way implying the wheel should be reinvented, in fact the
>>> code I posted was an example of how to use the MapGuideViewerAPI.js
>>> supplied DigitizePolygon(handler) function that you referred to.
>>> I did say that I would like to see some method to clear the
>>> digitized
>>> shapes after the function's handler has been called.  In MGOS 1.2
> after
>>> a polygon was digitized, it was destroyed.  In MGOS 2 with Fusion
> 1.1,
>>> the polygon stays on the map until the user closes their browser.
>>> -Mark P.
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
>>> Sent: Thursday, January 29, 2009 1:20 PM
>>> You know, you really do not need to reinvent the wheel, if you have
>>> already
>>> built a lot of code with the Basic Web Layouts.  Did you know that
>>> Fusion
>>> supports some retro digitizing methods?
>>> For example, I put the following in an INVOKESCRIPT in the Flexible
> Web
>>> Layout:
>>> top.parent.DigitizePoint(top.OnPointDigitized);
>>> I also have the OnPointDigitized in a JS file attached to the main
>>> frame/window.  So I reuse my code for both FUSION and Basic Web
>>> Layouts...
>>> Just check out the functions in the MapGuideViewerApi.js in the
>>> /www/fusion/MapGuide/ folder...
>>> They include:
>>> Refresh()
>>> SetSelectionXML(selectionXml)
>>> ZoomToView(x, y, scale, refresh)
>>> DigitizePoint(handler)
>>> DigitizeLine(handler)
>>> DigitizeLineString(handler)
>>> DigitizeRectangle(handler)
>>> They work just like the classic MapGuide Viewer API...pretty sweet.
>>> gordon
>>>> Absolutely.
>>>> My biggest beef with digitizing in Fusion is that when you digitize
> an
>>>> object (point/polygon/etc.) it stays on the map.  The existing
>>> functions
>>>> don't have a clear method to remove the digitized object, and my
>>>> programming skills aren't good enough that I want to mess with it.
>>>> It's very simple,
>>>> Add a reference to MapGuideViewerApi.js and call DigitizePolygon()
>>>> The DigitizePolygon function requires that you pass it a handler
>>>> Something similar to the following:
>>>> DigitizePolygon(CreateJobByPolygon);
>>>> function CreateJobByPolygon(polygon) {
>>>>    var geomText = polygon.Count;
>>>>    for (var i = 0; i < polygon.Count; i++){
>>>>        geomText += "," + polygon.Point(i).X + "," +
>>> polygon.Point(i).Y;
>>>>    Fusion.getWidgetById('Map').setCursor('auto');
>>>> //	here you would send your geomText to a web service, or aspx page
>>>> that would turn the coordinates into a linear ring
>>>> //    and then a polygon from there.  The geomText variable (in
>>>> this
>>>> particular situation) evaluates to something similar to
>>>> //    3,5000.00,5000.00,5050.00,5050.00,5100.00,5100.00
>>>> Of course you can format the way the coordinates are sent to your
>>>> application any way you want.
>>>> I would also recommend calling the DigitizePolygon() function from
> an
>>>> InvokeScript() widget, as I had some problems when I tried to
> actually
>>>> create a widget and call it from there.  Also, I prefer to change
>>>> my
>>>> cursor when the widget is activated, you can see I put it back to
>>> 'auto'
>>>> in the CreateJobByPolygon() function, but I like to set it to
>>>> 'crosshair' before the DigitizePolygon function is called.
>>>> -Mark P.
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
>>>> Dalakov
>>>> Sent: Friday, January 23, 2009 12:35 PM
>>>> To: MapGuide Users Mail List
>>>> Subject: [mapguide-users] Fusion and Digitizing
>>>> Hi all,
>>>> From what I read here, should I conclude that digitizing functions
> in
>>>> Fusion are not yet fully supported ?
>>>> I need to digitize a polygon on the map and save it permanently. I
>>> have
>>>> this working with AJAX viewer, but would like to port it to Fusion
>>>> Has anyone succeeded to  do this ?
>>>> Stefan Dalakov
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://n2.nabble.com/Fusion-and-Digitizing-tp2205560p2241352.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/Fusion-and-Digitizing-tp2205560p2241865.html
