[mapguide-users] Transparent Rasters in Mapguide Enterprise 2010
Mark Nichols
markn at spicergroup.com
Thu Jul 2 14:35:12 EDT 2009
Yes, last week I had problems with bi-tonal TIFF¹s. I had a reply from a
member of the list instructing me to use Irfanview and convert the TIFF¹s
the PNG¹s. It took a little work but yes, it did work. I do now have
transparent images in MapGuide. There were a few steps in Irfanview that
I¹m not remembering. If you have problems, repost and I¹ll try to step
through the process again.
Mark
On 7/2/09 1:51 PM, "Andy Morsell" <amorsell at spatialgis.com> wrote:
> It seems that the GDAL provider deals with transparency differently for
> different image formats. Others have mentioned this on this board as well.
> There was a post in the last week or so about this and they solved it by
> converting their imagery to transparent PNG¹s. Search the group for
> ³transparency² or ³transparent² and see what you come up with.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Johann Nothbauer
> Sent: Thursday, July 02, 2009 10:31 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Transparent Rasters in Mapguide Enterprise 2010
> Hi all!
> I'm trying to set up a map that contains GeoTIFF Images. Those images are the
> result of a re-projection from WGS84 to some projected system. That's why they
> have some "Nodata" strips on the edges (color info is paletted).
> Unfortunately MapGuide seems to ignore the NoData values, so there are
> overlaps between the images.
> Has anyone solved a similar problem?
> Any help appreciated,
> nothi
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090702/c3134e7e/attachment.html
