[mapguide-users] MapGuide (OpenSource/Enterprise) crashes when
using Oracle provider (King.Oracle)
Zac Spitzer
zac.spitzer at gmail.com
Thu Jul 2 21:16:47 EDT 2009
yup that's my all time fav mapguide error "An unclassified exception occurred."
On Fri, Jul 3, 2009 at 2:53 AM, Joel Carranza<jec at gatekeeper.com> wrote:
> I have a similar problem. MapGuide crashes sporadically on an layer being
> rendered by King.Oracle. I was unable to repeat the problem. That is - I
> restarted mapguide, deleted the tile that failed to render, and made the
> request a second time. It succeeded without a problem. Thus I can only
> assume it is not a problem with the source geometry or layer config, but
> some problem with concurrent map requests, as that is when it seems most of
> my problems occur.
> For example, I haven't have problems when I generate tiles via the MgCooker,
> but only when I am lazily rendering tiles as I am randomly view a map. Does
> MgCooker request tiles single-threadedly?
> Joel Carranza
> Gatekeeper Systems
> <2009-07-02T09:40:01> 5616 JV-1097,674,0 207.168.238.188
> Administrator
> Error: Failed to stylize layer: TIGERStreetByType
> StackTrace:
> - MgMappingUtil.StylizeLayers() line 776 file
> c:\osgeo\mapguide_21\mgdev\serve
> r\src\services\mapping\MappingUtil.cpp
> sathishpsk9 wrote:
>> Hi elkinsalcedo
>> I too same error log ......... have resolve it The problem is with
>> mapguide or with oracle ?
>> Thanks & Regards,
>> satish
> View this message in context: http://n2.nabble.com/MapGuide-%28OpenSource-Enterprise%29-crashes-when-using-Oracle-provider-%28King.Oracle%29-tp1819405p3196272.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
