[mapguide-users] Geometric join without spatial support
Jackie Ng
jumpinjackie at gmail.com
Mon Jul 6 03:17:02 EDT 2009
MapGuide does not support feature joins on geometric components.
- Jackie
dorshemer wrote:
> Hello,
> I'm trying to perform a geometric join between two tables without using
> any spatial DB support.
> I have an oracle table representing points on a map with X and Y fields,
> and a polygon SHP layer imported into MG. I would like to connect all the
> point from the first table with the polygons they are contained in,
> without Oracle Spatial support or writing new code.
> Is it even possible?
View this message in context: http://n2.nabble.com/Geometric-join-without-spatial-support-tp3208010p3210886.html
