[mapguide-users] King.Oracle error when USER is schema owner, SQL command not properly ended, (was: Maestro - DataConnection error when selecting override)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 6 03:19:53 EDT 2009
Hi Djonio.
I think this is a King.Oracle problem, so I changed the title, which will
hopefully attract the attention of the right people.
Regards, Kenneth Skovhede, GEOGRAF A/S
djonio skrev:
> Version: 1.0.9.39693
> KingOra 8.7
> MGOS 2.0.2
> When attempting to create a DataConnection I get the following error when
> attempting to set a Coordinate System Override:
> Maestro
> Failed to retrive coordinate info: The remote server returned an error:
> (559) MgFdoException.:
> An exception occurred in FDO component.
> ORA-00933: SQL command not properly ended
> Exception occurred in method MgServerGetSpatialContexts.GetSpatialContexts
> at line 129 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerGetSpatialContexts.cpp
> Seems that I do not have a problem when the USER for the connection is the
> schema owner.
> Would you be so kind as to offer an alternative when the USER is NOT the
> schema owner? or Where have I screwed up?
> I do in fact get this same error using Mapguide Studio 2009.
> http://n2.nabble.com/file/n3188552/error_msg.jpg
> r,
> dennis
