[mapguide-users] Feature Vertices
Tom Lazo tom.lazo at hotmail.com
Mon Jul 6 10:37:37 EDT 2009
Thanks,
I'll try that.
I'll notice you when it's finished.
Stygy/ Tom
Jackie Ng wrote:
> Given a MgFeatureReader that contains your feature(s):
> - Call its GetGeometry() method to get a byte reader
> - Convert this byte reader to a MgGeometry object by using a
> MgAgfReaderWriter object.
> - Call GetGeometryType() on the MgGeometry to determine what type of
> geometry it actually is.
> - Depending on the type, cast the MgGeometry to that given type (if not
> using PHP) and consult the relevant APIs for that derived geometry type.
> Basically you want to take note of any class methods that return MgPoint,
> MgCoordinate or MgCoordinateIterator objects.
> Hope that helps.
> - Jackie
> Tom Lazo wrote:
>> Hi all!,
>> Anyone knows how could i get the coordinates of the vertices of a
>> feature, Is there any function that do that?. Thanks.
>> Stygy / Tom
View this message in context: http://n2.nabble.com/Feature-Vertices-tp3205810p3213363.html
