[mapguide-users] 2.1 Beta (Fusion) Problems
Berdel, Brian brian.berdel at mcmtrans.com
Tue Jul 7 14:05:47 EDT 2009
There is an issue filed for it (it was filed by me #261), I just wanted to add this to the discussion as it is a show stopper for me to upgrade...I thought about breaking the maps up and giving them the ability to select different maps, but some clients weren't too excited about the idea...
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: Tuesday, July 07, 2009 1:44 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] 2.1 Beta (Fusion) Problems
argh - that shouldn't have changed, must be some difference in IE and
Firefox that we never noticed.  What we really need is a method of
generating a single image that contains all the icons - or at least
all that we know about when the map loads - we are doing this with
mapserver and the legend images are lightning fast now.  I think this
has been discussed previously and there may even be an issue filed for
it.  I'll try to remember to check on that (unless someone else does
first, hint, hint)
Cheers Paul
On 7-Jul-09, at 1:39 PM, Berdel, Brian wrote:
> Seems as though IE may load all of the images for the legend on page
> load, but firefox does not load them until a folder is expanded.
> Again, this was not a problem in Fusion 1.1.
> Brian
> ] On Behalf Of Berdel, Brian
> Sent: Tuesday, July 07, 2009 1:32 PM
> Subject: RE: [mapguide-users] 2.1 Beta (Fusion) Problems
> Thanks Dave, but I have tried that and it has the same result with
> multiple maps.  Maps with < 20 or so load fine in IE.  The maps I am
> using do have a pretty deep structure as well so there are a lot of
> images to load.  But it is only in IE that the problem exists.
> Brian
> ] On Behalf Of Dave Wilson
> Sent: Tuesday, July 07, 2009 1:03 PM
> Increase the memory settings in your php.ini. 256MB should cover
> most maps. Maps with 500+ layers may need up to 512. Maps with more
> than 750 layers may need more.
> Dave
> Sent: Tuesday, July 07, 2009 10:36 AM
> Also, A map with a lot of layers (50 +) takes an extremely long time
> to load in IE 7 & 8. No problem in FireFox and Chrome, but I receive
> the unresponsive script warning in IE.  I believe it has to do with
> the legend and the amount of time IE takes generating it.
> Brian
> ] On Behalf Of Mike Adair
> Sent: Monday, June 29, 2009 11:10 AM
> Also, patches are welcome if anybody has fixed any of these.
> I'm expecting to have more time to devote to Fusion over the summer.
> Mike
> Paul Spencer wrote:
>> Thanks Andy ... we've been quite at this end but really appreciate
>> the
>> traffic on these issues.  I'm hopeful that we can take a look at them
>> soon,
>> Cheers
>> Paul
>> On 26-Jun-09, at 5:56 PM, Andy Morsell wrote:
>>> I logged the three new issues in the Fusion Trac:
>>> http://trac.osgeo.org/fusion/ticket/263
>>> http://trac.osgeo.org/fusion/ticket/264
>>> http://trac.osgeo.org/fusion/ticket/265
>>> Andy
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
>>> Morsell
>>> Sent: Friday, June 26, 2009 10:56 AM
>>> To: 'MapGuide Users Mail List'
>>> Subject: [mapguide-users] 2.1 Beta (Fusion) Problems
>>> Hi all,
>>> I installed MGOS 2.1 Beta yesterday and here are several Fusion
>>> problems that I'm seeing:
>>> ·         Firefox is still prompting for user authentication even
>>> when SESSION is passed as a URL parameter.  It works ok in IE.  This
>>> has been mentioned in other threads here.
>>> ·         The Secondary and Main toolbars do not appear in all
>>> MapGuide templates.  It looks like they may be covered by other
>>> divs.  I see this in both FF and IE.
>>> ·         Tooltip hyperlinks do not appear as clickable hyperlinks
>>> anymore.  The text of the hyperlink appears though.  Both FF and IE.
>>> ·         Several tooltip problems that I have logged in Trac have
>>> not been fixed.  Some of these I even included the code fixes for!
>>> These include:
>>> http://trac.osgeo.org/fusion/ticket/232
>>> http://trac.osgeo.org/fusion/ticket/236
>>> http://trac.osgeo.org/fusion/ticket/237
>>> I will be voting -1 on releasing MGOS 2.1 until the above Fusion
>>> problems are fixed and a newer release of Fusion is included.  I
>>> realize that most of these problems are with Fusion, but as far as I
>>> am concerned Fusion and MGOS are intertwined in terms of
>>> functionality.  I will add the new items to the Fusion Trac in the
>>> next day or so.  My next step is to look at my ECW's and MrSID's
>>> with
>>> 2.1 since others have reported problems with that.
>>> Andy Morsell, P.E.
>>> Spatial Integrators, Inc.
>>> 47° 46' N 116° 49' W
>>> www.SpatialGIS.com
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>   Michael Adair
>   Senior Software Architect
>   DM Solutions Group Inc.
>   Office: (613) 565-5056 x26
>   madair at dmsolutions.ca
>   http://www.dmsolutions.ca
>   http://research.dmsolutions.ca
> Important notice to recipients:
> Copies of documents that may be relied upon by you are limited to
> the printed copies (also known as 'hard copies') that are signed and
> sealed by the Engineer and/or Land Surveyor. Files in electronic
> formats, or other types of information furnished by the Engineer and/
> or Land Surveyor to you such as text, data or graphics are for your
> convenience only. Any conclusions or information obtained or derived
> from such electronic files will be at the user's sole risk. When
> transferring documents in electronic formats, the Engineer and/or
> Land Surveyor makes no representation as to long-term compatibility,
> usability, or readability of the documents resulting from the use of
> software application packages, operating systems or computer
> hardware differing from those used by McMahon Associates, Inc. at
> the beginning of the project.
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
