[mapguide-users] Selecting and Zooming to Features - AJAX Viewer
prbabu
prbabu at openspatial.com.au
Tue Jul 7 20:07:05 EDT 2009
When I posted this message, it was NO.
Now I have created some base layers for smooth navigation and on doing this
the result is very unpredictable. Sometimes, the layers are visible first
and then
the selection happens(which is good) and if I try doing the same selection
again
after going to other areas of the map, the same old "delay" happens. Are the
tiles
being invalidated during the "delay"? I believe it could be controlled?!
On more questions on tiles, as the real-data is sourced from the
database,
will the base layer tiles be automatically updated on any changes which
could
have happened on the database-end?
-Praveen
Ivan Milicevic wrote:
> I thik that you can't speed up your selection. The delay depends on many
> things but the main reason is feature source (joins with database).
> Are you using the tiled base layers?
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Praveen
> Rajendra Babu
> Sent: Tuesday, July 07, 2009 2:23 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Selecting and Zooming to Features - AJAX
> Viewer
> Hi,
> Trying to figure out the best way to zoom and select features. This is
> w.r.to AJAX Viewer.
> What I do right now in sequence is:
> * Get the selection XML using MapGuide Web API
> * Call the function mapFrame.SetSelectionXML(...) with the
> selection XML
> * Call the function mapFrame.ExecuteMapAction(10)
> When doing this, there is a delay between the selection/highlighting of
> features on the map and then zooming to the features.
> Sometimes the delay between highlighting and zooming is minor and many
> times it is easily noticeable and this seems to be a bit "not-nice",
> in a very polite sense!
> Wondering, am I doing things the right way? Is there any better way
> to highlight and zoom features?
> Does Fusion come better in this basic set of activities?
> Thanks for your time.
> -Praveen
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Selecting-and-Zooming-to-Features---AJAX-Viewer-tp3217260p3222685.html
