[mapguide-users] After Installation, Services Missing
Bloozitis dsoper at uoregon.edu
Mon Jul 13 13:34:04 EDT 2009
I'm running version 2.0.2.3011, on a Windows 2003 server, using IIS, and the
ASP.Net environment.  I'm also having authentication issues for all users
except "Administrator".  Could this be IIS stuff?  I'm more than happy to
use Apache.
Cheers,
Dennis
Dave Wilson wrote:
> The manage services stuff was available at one point for support servers
> which only supported a subset of the full list of services. The ability to
> use Support Servers was removed/disabled. That stuff shouldn't even be
> visible? What version of MGOS have you installed?
> Something doesn't seem right.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dennis Soper
> Sent: Monday, July 13, 2009 9:14 AM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] After Installation, Services Missing
> No, I'm talking about when you log in to the web interface.  Under
> "Manage Servers->Configure Services".  The only services listed are:
> Site Services, Resource Services, Feature Service, and Tile Service.
> According to the help files there should also be Drawing, Mapping, and
> Rendering.  There was another page in the help files that might have
> told me how to fix this, but, unfortunately, I got a 404 error when I
> tried to access it.
> Cheers,
> Dennis
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
> Dalakov
> Sent: Saturday, July 11, 2009 8:08 AM
> Subject: Re: [mapguide-users] After Installation, Services Missing
> Hi Dennis,
> I do not understand very well what is the problem. From where are they
> missing ? Do you expect to see them as services running under windows ?
> Or you have used web tier tests and you do not get the expected results
> Under Windows services you should see only one service - MapGuide Server
> v.xxx
> I have not dared to install mgos 2.1 yet, but I don't expect that it
> will differ very much from previous versions in respect of what you are
> asking about
> Stefan Dalakov
> Dennis Soper wrote:
>> Hi all,
>> I've installed MapGuide Open Source on a test machine. The following
>> services are missing from the web-based configuration: Drawing,
>> Mapping, and Rendering. I've loaded it on a Windows 2003 box, using
>> IIS, and I've tried both the .NET and PHP environments.
>> How do I get these services?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/After-Installation%2C-Services-Missing-tp3240851p3251900.html
