[mapguide-users] setActiveTab in Fusion MGOS Beta 1
Paul Spencer
pagameba at gmail.com
Tue Jul 14 11:17:00 EDT 2009
try, instead:
tab3.setActive(true);
Cheers
Paul
On 12-Jul-09, at 3:40 PM, GreenMapSanMiguel wrote:
> I would like to programatically switch from the OverviewMap to
> SelectionPanel, but can't get it to work by calling the
> showSelectionPanel
> function, which for my application is:
> var showSelectionPanel = function() {
> tabbox2.tabSet.setActiveTab(tab3);
> The setActiveTab function is executing, but it is not doing everything
> needed to make the switch. Here is an example of the incomplete
> setActiveTab:
> http://smamap.com/mapguide/GreenMap/SanMiguelDeAllende/index.php?LAYER=food&LOC=BOVE
> It switches away from the OverviewMap but doesn't display the
> contents of
> the Selection panel (or highlight the tab.) I get similar results
> switching
> to any of the other tabs. If you click on the 'select' tab, then the
> correct information will display.
> Is there an additional call I need to make or fields I need to set
> up in
> advance?
> Thank you for your help!
> Andy Baltimore
> p.s. Here's an example that does not try to change tabs. The
> selection is
> working but the use must click the select tab:
> http://smamap.com/mapguide/GreenMap/SanMiguelDeAllende/indexNoSwitch.php?LAYER=food&LOC=BOVE
> View this message in context: http://n2.nabble.com/setActiveTab-in-Fusion-MGOS-Beta-1-tp3246967p3246967.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
