[mapguide-users] set "filter applied to data" programmatically
Tom Lazo / Stygy
tom.lazo at hotmail.com
Tue Jul 14 11:51:41 EDT 2009
Hi Vittorio,
You could modify the Select Widget adding a filter option i.e.
options.filter = "(ID_FICHA = "1")";
The query.php will automatically filter the features with that value on the
property ID_FICHA.
Hope it helps.
Tom
vittorio wrote:
> Hi all,
> how to set "filter applied to data" to a layer programmatically and make
> visible the result into map viewer?
> Thanks,
> Vittorio
http://n2.nabble.com/file/u222842/warning.png Stygy is not a living being!
View this message in context: http://n2.nabble.com/set-%22filter-applied-to-data%22-programmatically-tp3257298p3257617.html
