[mapguide-users] Mapguide Library Folders
Dave Wilson
dave.wilson at autodesk.com
Thu Jul 16 16:33:59 EDT 2009
What do you want to do with the files?
During the publish you specified a folder to publish to in the MapGuide Site Explorer. All the files are created in a Data subdirectory under the folder name you specified.
You can use MGE API's to EnumerateResource, EnumerateResourceData and GetResourceData and get the files from the Repository.
Otherwise if you were simply looking to find the files manually after a single publish you can view the Repositories\Library\DataFiles\ in Windows Explorer and sort by date and see the files that were created. You could search on .dwf and find the files.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Luis Paolini
Sent: Thursday, July 16, 2009 1:48 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide Library Folders
Hi All,
I'm working with Autodesk Map 3D to publish some DWG files to Mapguide in DWF format. The process is:
1. File -> More Plotting Options -> Publish to Mapguide
2. Connect to Mapguide
3. Create a Folder
4. Publish
After that, looking into Mapguide Server Folders, I understand that my DWF file was stored somewhere inside /Library folder.
The problem is that the folders are named by Mapguide using some pattern (Ex: dfaaf08a-ffff-ffff-8000-00c09f3e1b02).
My question is: How can I discover in which folder the dwf published is stored?
Regards,
Luis
__________ Information from ESET Smart Security, version of virus signature database 4251 (20090716) __________
The message was checked by ESET Smart Security.
http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090716/08f2335a/attachment.html
