[mapguide-users] MG Error Out of memory, bad allocation
Stefan Dalakov s.dalakov at mapware.net
Tue Jul 21 08:29:52 EDT 2009
Hi Jürgen
One of the options may be to merge together files.
I have an image, 32000x16000 tiled RGB tiff, 1.7GB in size which is
served like a lightning by an old computer, not even designed to be a
server, with 1.5 GB of RAM.
Software configuration - same as yours.
By merging rasters you can reduce the number of files almost 60 times,
which means that you will have 15-20 files, roughly.
Of course, you know better, if your project allows this, but in general,
MGOS seems to handle easier a small number of big files, rather than a
big number of small files.
Best regards : Stefan Dalakov
juergen.konradt at bluewin.ch wrote:
> Hi,
> I have a problem with a rasterlayer (not tiled).
> It is a layer using about 1000 TIFF-Files (RGB, 3000x3000 pixel, scale 1:1000).
> The visibility of the layer is 1:100 to 1:5000.
> If I load the map (sacle 1:2000) I get the error: Out of memory. bad allocation.
> If I reduce the number of tiff-files in the folder (500) I get no error but the map is loading very, very slow.
> If I change the format from tiff to jpg or ecw (all 1000 files) I get no error but the map is also very slow.
> I get the same error with Autodesk Raster FDO and OSGEO Gdal
> MGOS 2.02 or MGOS 2.1.0 Beta
> W2003 Server SP2
> IIS 6.0
> AjaxViewer (JSP)
> is there any solution for this problem?
> Jürgen
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
