[mapguide-users] Regarding Shape file
sathishpsk9 sathishpsk9 at gmail.com
Wed Jul 22 22:28:17 EDT 2009
Hi Kenneth Skovhede
Thanks for your timely reply.
1.It looks right, but I think the FeatureName should be:
SHP_Schema:india_st
Ya your are right . now changed it to SHP_Schema:india_st
2.For (1), you can use any folder you like, as long as the web app has
write access,
and MapGuide has read access. I recommend using a folder that is only
used for this purpose.
I am using my D drive  .. My web app able to write to it but i don whether
Mapguide has read permissions ..
3.For step (9), did you remember to set the layer visible?
mylayer.SetVisible(true);
4.You can also use this method if you call SETRESOURCEDATA after step 4,
to upload the file.
(Remember to set the path in step 3 to %MG_DATA_FILE_PATH%).
   I am using foolowing method
resourceSrvc.SetResource(fetids, bytscrf.GetReader(),null);
and storing all resource to Library:// repository
5.Try to see if the error log has any messages.
error log:
<2009-07-23T07:39:17> 			Administrator
 Error: Failed to stylize layer: india
        An exception occurred in FDO component.
        Schema 'SHP_Schema' not found.
 StackTrace:
  - MgMappingUtil.StylizeLayers line 775 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp
<2009-07-23T07:39:19> 			Administrator
 StackTrace:
what does above error indicate ?
Thanks & Reagrds,
Satish Kumar
View this message in context: http://n2.nabble.com/Regarding-Shape--file-tp3270233p3307159.html
