[mapguide-users] SQL Server 2008 Query
Akram
akram at gsg-eg.com
Wed Jul 29 07:59:04 EDT 2009
Hi Worshond,
to make a selection in your MG solution you should use
'MgFeatureQueryOptions' object in order to filter your features in map,
after execute your query in SQL server and get your value, use this value to
filter your features as following:
MgFeatureQueryOptions districtQuery = new MgFeatureQueryOptions();
districtQuery.SetFilter("landID = '" + value + "'");
and to display the feature on map use 'MgFeatureReader' object to read the
data source and get X,Y for your target feature
then use this code to zoom to uour feature
mapFrame.ZoomToView(" + XCoord + "," + YCoord + ", 2500 ,true)
Regards,
http://gsg-eg.com
http://n2.nabble.com/file/u111068/head2.jpg
GeoService
View this message in context: http://n2.nabble.com/SQL-Server-2008-Query-tp3348261p3349222.html
