[mapguide-users] mapguide examples won't display, can't create new resources, possible permissions setup problem?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jul 30 12:14:13 EDT 2009
I've looked into it and I cannot get the error that you describe.
If you can post a stacktrace (should be included in the Help/Last
exception menu),
I can investigate some more.
Are you using the Administrator login?
By "load a new DataConnection", do you mean New -> FeatureSource ?
What is the type of FeatureSource that you are creating?
Regards, Kenneth Skovhede, GEOGRAF A/S
Kenneth Skovhede, GEOGRAF A/S skrev:
> I think that is an issue with Maestro.
> It should definately not create temp resources in Library://
> Do you have a full message?
> Perhaps from the "Help" -> "Last exception" ?
> If the maps fail to load, there is usually a message in the
> error log for MapGuide. The path for the log can be found in
> serverconfig.ini
> efrench skrev:
>> Hello all,
>> I’m very much new to MapGuide. After compilation from Subversion source
>> failed (I’m using Fedora 9; the Makefiles generated by ./configure
>> resulted
>> in numerous errors and the like) I downloaded a copy of the Live CD,
>> loaded
>> it into a virtual machine, and copied the MapGuide installation to the
>> server where I plan to run it. All the libraries I need are in place,
>> and
>> apache and mgserver appear to start up without trouble. However, I
>> appear to
>> have some permissions set wrong or something. Although the map viewer
>> itself
>> will load in all the examples, the actual maps do not load. An
>> attempt to
>> load a new Data connection in Maestro fails with the error:
>> Unable to create the resource Library://{hex sequence} Error message:
>> System.Net.WebException: Error getting response stream (ReadDone2):
>> ReceiveFailure -à System.Exception: at System.Net.WebConnection
>> Any clue on what the problem is here? Any help would be greatly
>> appreciated.
>> Also, I notice mgserver won't start as a daemon; it only starts in
>> interactive mode, but perhaps this doesn't matter so much.
>> Thanks,
>> Emerson French
