[mapguide-users] Selection Limit?
Nickthetemp
nickthetemp at gmail.com
Thu Jul 30 12:58:08 EDT 2009
I was able to limit the selection size by changing the following"
$selection2->AddFeatures($Samplayer, $featureReader, 0);
to
$selection2->AddFeatures($Samplayer, $featureReader, 200);
This limits the selection to 200
the 0 is used for select all, just incase someone else is trying to figure
this out :)
Nick
Mauricio Villablanca wrote:
> You are right. The 2010 API documentation omitted that method and it's no
> longer valid.
> Nickthetemp wrote:
>> I tried the GenerateFilters method, but it is not a valid method for mge
>> 2010.
>> It just gave a warning saying it was not a valid method.
>> If there is a way to limit the selection to approx 200 items, it would
>> also solve my prob.
>> I know in mge 2009, There was a selection size varible in the
>> serverconfig.ini file but it is no longer present in mge 2010.
>>> I noticed $selection2->GenerateFilter($layer, $layerClassName) doesn't
>>> always generate a valid filter in MGE2009. Use GenerateFilters instead
>>> Check my post in the "Problem with MgSelection's SelectedFeatures"
>>> thread started by Tom Lazo for selecting features.
>>> Nickthetemp wrote:
>>>> Hello
>>>> I am using the following code to read through a selection and grab a 7
>>>> digit number, which is then put into an array:
>>>> $layerClassName = $layer->GetFeatureClassName();
>>>> $selectionString = $selection2->GenerateFilter($layer,
>>>> $layerClassName);
>>>> // Get the feature resource for the selected layer
>>>> $layerFeatureId = $layer->GetFeatureSourceId();
>>>> $layerFeatureResource = new
>>>> MgResourceIdentifier($layerFeatureId);
>>>> // Apply the filter to the feature resource for the
>>>> selected layer. This returns
>>>> // an MgFeatureReader of all the selected features.
>>>> $queryOptions->SetFilter($selectionString);
>>>> $featureReader =
>>>> $featureService->SelectFeatures($layerFeatureResource, $layerClassName,
>>>> $queryOptions);
>>>> // Process each item in the MgFeatureReader, displaying the
>>>> PID
>>>> while ($featureReader->ReadNext())
>>>> $valArray[$counter] = $featureReader->GetInt32('PID');
>>>> $counter = $counter + 1;
>>>> The code works fine until I hit a larger selection number. Is there a
>>>> limit on the number of features that can be selected from a database?
>>>> I get the following error when the selection is big:
>>>> An exception occurred in FDO component. RDBMS: [IBM][CLI
>>>> Driver][DB2/LINUX] SQL0010N The string constant beginning with ""MAPI"
>>>> does not have an ending string delimiter. SQLSTATE=42603
>>>> Any help would be appreciated
>>>> Nick
View this message in context: http://n2.nabble.com/Selection-Limit--tp3321984p3357551.html
