[mapguide-users] 2.1 installation problem
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Mon Jun 1 14:46:43 EDT 2009
I'm accessing it straight from the start menu - which seems to be using
localhost (if that never works, perhaps someone should change the
installer so it doesn't use it). I just tried using my ip, (and also
tried 127.0.0.1 for the heck of it) but it didn't work either....same
thing.
Andrew
On 6/1/2009 3:20 PM, Martin Morrison wrote:
> You are typing the full path rather than trying to browse the dir
> structure correct? E.G. http://localhost/MapGuide/mapadmin/login.php
> You can no longer go to http://localhost/MapGuide/mapadmin This is a
> very good thing...
> Martin
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Monday, June 01, 2009 2:11 PM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] 2.1 installation problem
> I'm trying to install the 2.1 beta on a Windows 2000 virtual machine -
> I had had 2.0 on there with no problems (with IIS)...I uninstalled 2.0
> completely, then installed 2.1 with Apache - but when I try to access
> anything (MapAgent test pages, MapGuide site admin) I get a 403
> (access forbidden). I don't know Apache - any suggestions? I'm sure
> it's simple....but I could find anything online that was applicable.
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
