[mapguide-users] Connect to PostGis3.2 data
euskalmap
ziburudebian at free.fr
Tue Jun 2 03:45:35 EDT 2009
Sorry, I have forget remplace the name of table in the second query ; so here
is the result of the second query :
http://n2.nabble.com/file/n3010782/res2.jpg
Bruno Scott wrote:
> This is my generic connection on windows
> username : postgres
> Password : root
> Service : mydatabase at mymachine:5432
> Datastore : public
> If you have a logged provider, you should see some interesting query
> The first one will scans all avalable table/views
> SELECT n.nspname AS schemaname,c.relname AS tablename
> FROM pg_class c, pg_namespace n
> WHERE c.relnamespace = n.oid AND
> c.relkind IN ('r','v') AND
> (c.relname NOT LIKE 'pg_%') AND
> (c.relname NOT LIKE 'spatial_ref_sys%') AND
> (c.relname NOT LIKE 'sql_%') AND
> (c.relname NOT LIKE 'geom%') AND
> n.nspname = 'public'
> ORDER BY c.relname
> You should try to run it on your machine (replace public by your own
> schema)
> The second one is runned for each table/view
> SELECT a.attnum AS ordinal_position, a.attname AS column_name,t.typname AS
> data_type, a.attlen AS character_maximum_length,a.atttypmod AS modifier,
> a.attnotnull AS notnull,a.atthasdef AS hasdefault, d.adsrc AS
> defaultVal,a.attnum = ANY (i.indkey) AS isprimarykey, i.indkey AS primKey,
> i.indisprimary AS indisprimary
> FROM pg_attribute a LEFT OUTER JOIN pg_attrdef d ON a.attrelid =
> d.adrelid,
> pg_type t,
> pg_namespace n,
> pg_class c LEFT OUTER JOIN pg_index i ON i.indrelid = c.oid
> WHERE a.attnum > 0 AND a.attrelid = c.oid AND
> a.atttypid = t.oid AND
> t.typname !~ '^geom' AND
> i.indisprimary = 't' AND
> c.relname = 'mytable' AND
> ORDER BY a.attnum;
> Try this and tell me what it returns
> Bruno
View this message in context: http://n2.nabble.com/Connect-to-PostGis3.2-data-tp2980072p3010782.html
