[mapguide-users] Saving a point to map permanently
sathishpsk9 sathishpsk9 at gmail.com
Tue Jun 9 08:17:26 EDT 2009
 Hi saloua,
             Thanks for reply .... but i what have you disscussed is not the
problem.... because i have taken co-ordinates from Digitized()
method......that might be beacuase of map ... bcoz i open it in session and
whatever i add to it are being stored in session only ....and when i refresh
the page session id changes ... so the changes i made not in current
sessions .....so any other way out or if possible send your code which does
this .......... i could analyze
my code of adding layerdefination which have created to add point to current
map goes like this
        String layerDef = "Library:" + "//" + "ShapeFile" +  "/" +
"lay1.LayerDefinition";
        MgResourceIdentifier layerDefId = new
MgResourceIdentifier(layerDef);
        resourceSrvc.SetResource(layerDefId, layerDefContent,
null);//layerdefContentis  layerdefination which have created to add point
to current map
        MgLayer myLayer = new MgLayer(layerDefId, resourceSrvc);
        myLayer.SetName(myLayerName);
        myLayer.SetVisible(true);
        myLayer.SetLegendLabel("Point oF Interest ");
        myLayer.SetDisplayInLegend(true);
        myLayer.SetSelectable(true);
        map.GetLayers().Insert(0, myLayer);
        //map.GetLayers().Add(myLayer);
        map.Save(resourceSrvc);
        myLayer.ForceRefresh();
thanks & regards,
Satish
View this message in context: http://n2.nabble.com/Saving-a-point-to-map-permanently-tp3041754p3049093.html
